41CL - Is my hp 41C a correct candidate to UPGRADE? - Printable Version
+--- Thread: 41CL - Is my hp 41C a correct candidate to UPGRADE? (/thread-11098.html)
41CL - Is my hp 41C a correct candidate to UPGRADE? - Podalirius - 07-20-2018 07:15 AM
Hi, I have purchaded a hp 41C with the assurance that it is upgradable to a Sy 41CL.
I open my 41C to verify if the connector for the Nut board is as the one
in the sy41cl.pdf manual, and I am not sure that it is OK.
My 41C has the serial number 2148S42321.
I maked an attachement for a photo of the connector inside my 41C.
Thank you so much for all your help!!!
[attachment=6143]
RE: 41CL - Is my hp 41C a correct candidate to UPGRADE? - rprosperi - 07-20-2018 01:50 PM
(07-20-2018 07:15 AM)Podalirius Wrote:  Hi, I have purchaded a hp 41C with the assurance that it is upgradable to a Sy 41CL.
Yes, this should work OK for a CL upgrade, assuming it is working properly as a 41C now. This 41C has had its lower posts recently repaired using parts from "The Calculator Store"
RE: 41CL - Is my hp 41C a correct candidate to UPGRADE? - Podalirius - 07-20-2018 06:33 PM
Hi, Thank you very much for your help.
The 41C is working fine. Is repaired by The Calculator Store
and I purchased it form this site.
