July 2018 little math problem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: July 2018 little math problem (/thread-11121.html) Pages: 1 2 |
RE: July 2018 little math problem, mini-challenge - Albert Chan - 07-28-2018 01:15 PM I like to show why Complement Symmetry work, and why it sometimes does not. I use a simpler 3-sided zigzag to illustrate. Instead of using numbers 1 to 7, think of it shifted, from -3 to 3. So, complement symmetry is just changing the sign of all numbers. If a solution with a non-zero sum S, complement symmetrical solution has sum -S Swapping values, reversing ... is not going to change the new sum back to S Thus, the complement solution is unique. If all cases were like that, we could return half as many solutions, and let user build the other half. If the solution had zero sum, it's complement symmetrical solution also had zero sum. Example: [-2,3,-1,0,1,-3,2] Above solution, complement (sign change) + reversing digits = itself. The 2 symmetries overlap (*) :-( In order to "cut" primary in half, above situation cannot happen. We required half of solutions to be able to derive from the other half. Mini-Challenge: (*) 2 symmetries does not overlap for sides = 4, 6, 8, 10, 12, 14, ... Why ? In other words, for even sided zigzag, we can indeed reduce primary solutions in half. You do not need a calculator to prove this ... RE: July 2018 little math problem - DavidM - 07-28-2018 04:22 PM Thanks to all who are sharing their various analyses of this deceivingly simple-looking puzzle! It's a great example of how the application of deductive reasoning can greatly reduce the work needed to solve a problem. (07-26-2018 03:43 PM)Thomas Klemm Wrote: We can start with \(e\in\{1\ldots9\}\). And then let \(c\) and \(g\) be different digits with \(c<g\). This gives us \(9\times\binom{8}{2}=252\) possibilities. So far I've made it up to Thomas' optimizations, which I've translated into an RPL/ListExt implementation. As expected, this brought the run time down considerably from the previous versions. Real 50g: 63.9s Emu48+ on laptop: 1.68s I'm still trying to wrap my ahead around Albert's and Valentin's approach, especially in terms of how they might translate to a more familiar language. This has proven to be an intriguing problem! Code: Spoiler... RE: July 2018 little math problem - Albert Chan - 07-29-2018 12:10 AM (07-28-2018 04:22 PM)DavidM Wrote: I'm still trying to wrap my ahead around Albert's and Valentin's approach, Hi, DavidM: With comments, I can finally understand the code. Thanks. I do not own any HP calculators (except a hand-me-down HP-12C) I tried coding in Python, and possibilities is not as high as 252 Brute force all possible values of sum, and it only need 144 Even if sum of 15 is added (why?), it will only reach 180 With complement symmetry, it could be reduced to 72 4 s = 45 + c + e + g = (45 + 1 + 2 + 3) to (45 + 7 + 8 + 9) = 51 to 69 = 52, 56, 60, 64, 68 --> s = 13, 14, 15, 16, 17 when s = c + d + e =15, c + e + g = 4 s - 45 = 15, which imply d=g, thus s != 15 Code: for s in [13, 14, 16, 17]: And, the expected result ... [3, 9] 1 8 4 7 2 [5, 6] [6, 7] 1 5 8 4 2 [3, 9] [5, 8] 1 6 7 4 3 [2, 9] [4, 8] 2 9 3 5 6 [1, 7] [1, 9] 4 8 2 7 5 [3, 6] [2, 8] 4 9 1 7 6 [3, 5] [5, 7] 4 3 9 1 6 [2, 8] [3, 9] 4 5 7 1 8 [2, 6] [4, 7] 5 3 8 2 6 [1, 9] [1, 8] 7 6 3 4 9 [2, 5] [1, 7] 8 6 2 5 9 [3, 4] [4, 5] 8 3 6 2 9 [1, 7] RE: July 2018 little math problem - Albert Chan - 07-29-2018 01:02 PM (07-28-2018 01:15 PM)Albert Chan Wrote: Mini-Challenge: The problem of complement symmetry was its overlap with reversing digits symmetry. This led to its inability to generate unique symmetrical solutions. Prove by contradiction: To follow the notation of the 4-sided zigzag, let e be middle number of an even-sided zigzag. Let's shift the numbers, so available digits = -side to side Assume 2 symmetries overlap, middle zigzag look like this: (c d e f g) => (c d 0 -d -c) For the center, sum = 0, e = 0, we have: (c d e f g) => (c -c 0 f -f) so, for both equation g = -c = -f, or c = f But, all numbers must be different, assumption was wrong => 2 symmetries have no overlap. For even-sided zigzag, we can cut primary solutions in half. QED RE: July 2018 little math problem - Albert Chan - 07-29-2018 10:27 PM Slight changes to my posted Python code (post 23) dramatically reduce checks down to 17 cases Only patch is to change the loop range: s range = [13, 14] c range = range(max(1, ceg-8-9), min(9, ceg//2)) g range = range(c+1, min(10, 10 - s + ceg)) s range is reduced by taking advantage of 10-Complement Symmetry c range is reduce because of this: c + e + g = ceg min(c) = ceg - max(e + g) = ceg - 8 - 9 max(c) = ceg - min(e) - min(g) = ceg - 1 - (max(c) + 1) max(c) * 2 = ceg - 2 max(c) < floor(ceg / 2) g range is reduced because d = s - c - e = (s - ceg) + g Since g is increasing inside loop, d is also increasing, remove invalid d, we get: max(d) = (s - ceg) + max(g) < 10 max(g) < 10 - s + ceg With above ranges, these are the only cases checked: #1: 1 8 4 7 2 => [3, 9] 1 8 4 7 2 [5, 6] #2: 1 9 3 7 3 #3: 2 9 2 8 3 #4: 1 5 8 4 2 => [6, 7] 1 5 8 4 2 [3, 9] #5: 1 6 7 4 3 => [5, 8] 1 6 7 4 3 [2, 9] #6: 1 7 6 4 4 #7: 1 8 5 4 5 #8: 1 9 4 4 6 #9: 2 6 6 5 3 #10: 2 7 5 5 4 #11: 2 8 4 5 5 #12: 2 9 3 5 6 => [4, 8] 2 9 3 5 6 [1, 7] #13: 3 7 4 6 4 #14: 3 8 3 6 5 #15: 3 9 2 6 6 #16: 4 8 2 7 5 => [1, 9] 4 8 2 7 5 [3, 6] #17: 4 9 1 7 6 => [2, 8] 4 9 1 7 6 [3, 5] 16X Symmetries: head swap, tail swap, reversing digits, 10-complement Solutions = 6 primary solutions * 16 = 96 RE: July 2018 little math problem - Komanguy - 07-31-2018 08:19 PM Cyrille de Brebisson, could you explain your algorithm? RE: July 2018 little math problem - Albert Chan - 07-31-2018 10:49 PM Hi, Komanguy I did a Python version of the zigzag Hp Prime program. With comments, perhaps this is easier to follow: Code: def zigzag_prime(slot, filled): RE: July 2018 little math problem - Komanguy - 08-01-2018 11:31 AM Thanks a lot, Albert. Cheers. RE: July 2018 little math problem - pier4r - 08-01-2018 02:13 PM Albert kudos for the effort and sharing! RE: July 2018 little math problem - Albert Chan - 08-03-2018 05:25 PM I revised zigzag.pi with better constraints Code: import cp. % Usage: picat zigzag.pi [Sides=4] For 10-sided zigzag, speed (vs. original) = 2.37X, or 137% faster (finished in 111 seconds) RE: July 2018 little math problem - Dave Britten - 08-13-2018 01:54 AM Here's my straight-forward Turbo Pascal version. It's just depth-first tree traversal with bail-out checks at each vertex. Takes about 12 seconds to find 96 solutions to the 4-sided 1-9 puzzle on my 200LX. Code:
