Hp prime - bricked -stuck at the Hp logo - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Hp prime - bricked -stuck at the Hp logo (/thread-11288.html) Pages: 1 2 |
RE: Hp prime - bricked -stuck at the Hp logo - Tim Wessman - 09-05-2018 05:05 AM One last thing to try, can you remove the battery and plug in the USB to power it? Does it start without the battery installed? RE: Hp prime - bricked -stuck at the Hp logo - Matheus Hermes - 09-05-2018 03:55 PM (09-05-2018 05:05 AM)Tim Wessman Wrote: One last thing to try, can you remove the battery and plug in the USB to power it? Does it start without the battery installed? Yes. RE: Hp prime - bricked -stuck at the Hp logo - Tim Wessman - 09-05-2018 04:17 PM So that is a "yes, the calcualtor boots"? If so, your battery is bad I think. Else you could also try getting the calculator all booted up, leaving it plugged in, and replace the battery while running. Leave it for a bit after that and see if it starts charging. RE: Hp prime - bricked -stuck at the Hp logo - Matheus Hermes - 09-05-2018 05:32 PM (09-05-2018 04:17 PM)Tim Wessman Wrote: So that is a "yes, the calcualtor boots"? Hey Tim, I recorded a video. https://youtu.be/CRE5L1CP-OU RE: Hp prime - bricked -stuck at the Hp logo - Zaphod - 09-06-2018 09:52 AM What else can you on diag screen, can you confirm what it thinks its FW version is ? and perhaps perform the other tests on this screen |
