CAS laplace transform w/ undefined function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: CAS laplace transform w/ undefined function (/thread-11388.html) |
CAS laplace transform w/ undefined function - wsprague - 09-13-2018 04:35 AM Hi all, Working through my circuit book (Thomas & Rosa 2001), we are taking laplace transforms of undefined functions. For example: L(dv(t)/dt + 6v(t)) = sV(s) + v(0) +6V(s) How would I do this HP Prime / xcas? I would be happy with a link if there is one, but I have searched the docs as best I could. As you can probably guess, we then solve for V(s) = .... and take the inverse transform, but that isn't the part where I am stuck currently. ( And forgive me if I got the above transform wrong, I am sure it is close and conveys the idea...) Thanks! RE: CAS laplace transform w/ undefined function - parisse - 09-13-2018 05:47 AM There is nothing builtin to handle unassigned function. If you want to check integration by part, you can run ibpu(exp(-s*x)*diff(f(x),x),exp(-s*x)) RE: CAS laplace transform w/ undefined function - wsprague - 09-14-2018 04:48 AM Do you or anyone have advice on how to use the laplace() transform function to solve a differential like the following? dv(t)/dt + 6v(t) = sin(t) In the book you take laplace transforms of each side, solve for V(s), but I don't see how to do that in xcas. (Not sure why you suggested integration by parts, but it is highly likely I missed something.) Thanks! RE: CAS laplace transform w/ undefined function - parisse - 09-14-2018 06:55 AM Replace v(0) by it's value, solve for V(s) y:=laplace(sin(t),t,s); [vsol]:=solve(s*vs + v0 +6vs=y,vs); ilaplace(vsol,s,t); Check with desolve: desolve([v' + 6v = sin(t) ,v(0)=v0],t,v) |
