XCAS float precision - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: XCAS float precision (/thread-11525.html) |
XCAS float precision - Albert Chan - 10-04-2018 02:52 PM I finally join the club, and downloaded XCas (for Windows 32-bits) If XCas float default is IEEE double precision, I should get this: Python: 3.141592653589794 - 3.141592653589793 => 8.88e-16 This is above in hex-float, where ULP = 2^-51 ~ 4.44e-16: 0x1.921fb54442d1aP1 - 0x1.921fb54442d18P1 = 2 ULP ~ 8.88e-16 Instead, I get something unexpected, suggesting XCas uses 54-bits float (or more) (Also, returned float is not normalized, with a zero before decimal point) XCAS: 3.141592653589794 - 3.141592653589793 => 0.111e-14 (2.5 ULP ?) Just to confirm above with 54-bits float math (now, ULP = 2^-52) 0x1.921fb54442d1a0P+1 - 0x1.921fb54442d178P+1 = 5 ULP ~ 1.11E-15 (match above) RE: XCAS float precision - parisse - 10-04-2018 07:22 PM Xcas is using longfloats (via MPFR) for representation of floats having more than 14 digits. RE: XCAS float precision - Albert Chan - 10-04-2018 09:36 PM (10-04-2018 07:22 PM)parisse Wrote: Xcas is using longfloats (via MPFR) for representation of floats having more than 14 digits. Thanks you. It now make sense. pibf := 3.141592653589793 // bigfloat pi53 := 3.141592653 + 5.89793-10 // machine float evalf(pibf, 20) => 3.1415926535897928940 // big float confirmed evalf(pi53, 20) => 3.14159265359 // pi53 is 0.5 ULP bigger than pibf It seems when big float mixed with machine float, big-float is "demoted". evalf(pibf + 0.0, 20) => 3.14159265359 pibf - pi53 //==> 0.0 pibf == pi53 //==> true, big float demoted before comparison. RE: XCAS float precision - parisse - 10-05-2018 06:04 PM Indeed. Mixing floats and long floats will convert long float to float. |
