Request: symbolic manipulation on select part - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Request: symbolic manipulation on select part (/thread-11620.html) |
Request: symbolic manipulation on select part - compsystems - 10-20-2018 09:00 PM Currently you can select part of an expression in the input line [shift + view] then [begin..end], but you can not manipulate it symbolically as it does xcas and other cas. My request is that in the menu [begin] [end] [] [all] [cut] [copy] Include a menu for symbolic manipulation [begin] [end] [Symbolic] [all] [cut] [copy] where for example symbolic has several submenus: simplify, normal, factor, approx, eval (x-2)^2*(3*x-1) [symbolic] (x^2-4*x+4)*(3*x-1) RE: Request: symbolic manipulation on select part - BruceH - 10-24-2018 12:08 AM So a bit like the [ALGEBRA][FORM] menu from the HP28C/S which morphed into the [EQUATION][RULES] menu on the HP48SX/GX but then got dropped from the 49 and 50, unfortunately. |
