emu41p + HP-IL - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: emu41p + HP-IL (/thread-11621.html) |
emu41p + HP-IL - S0N1C - 10-21-2018 07:24 AM Hi, all I have Portable Plus with emu41p installed(ROMs) + Ludlum 2200-12(device that I want to control) I tested HP-IL loop via built-in in Portable Plus testing utils(shift+extend char+F8) and loop closed, 1 device found, so I hope everything works and connected ok. But when trying to communicate with device in emu41p by using OUTA - nothing happens, device doesn't react, INA - I'm getting TRANSMIT ERR Maybe Portable Plus or emu41p need some additional configuration? Also strange thing, when activating ALPHA and typing command to send(before OUTA)- some symbols become *, some not, and they are in lower register(not sure if it matters), so maybe I'm not actually sending correct commands to device? Here is simplest programs I tried: LBL "CNT" "C" OUTA - nothing happens LBL "VER" "VR" - entering like ALPHA vr(both symbols displayed as **)ALPHA OUTA - XEQ ALPHA OUTA(displayed ok, upper case)ALPHA INA - getting TRANSMIT ERR AVIEW RE: emu41p + HP-IL - Sylvain Cote - 10-22-2018 02:14 AM One of the thing you could do is to try to get the Device ID of your unit. You need the 82160A HP-IL & 82183A Extended-I/O modules to do the following steps: Code: AUTOIO RE: emu41p + HP-IL - rprosperi - 10-22-2018 02:49 AM (10-22-2018 02:14 AM)Sylvain Cote Wrote: One of the thing you could do is to try to get the Device ID of your unit. JFG posted info about this device (I believe from the manual) on the newsgroup as follows: Quote:The Ludlum 2200-12 has an ID$="LMI2200-12" and an AID=7Eh (general analytical or scientific instrument). RE: emu41p + HP-IL - S0N1C - 10-22-2018 06:28 AM (10-22-2018 02:14 AM)Sylvain Cote Wrote: You need the 82160A HP-IL & 82183A Extended-I/O modules to do the following stepsI'm not sure if 82183A ROM built in into emulator, but I'll try, thank you RE: emu41p + HP-IL - J-F Garnier - 10-22-2018 07:20 AM (10-21-2018 07:24 AM)S0N1C Wrote: But when trying to communicate with device in emu41p by using OUTA - nothing happens, device doesn't react, INA - I'm getting TRANSMIT ERR Reason is that there is not only your instrument in the loop but also the emu41p internal virtual devices (DISPLAY, HDRIVE1, DOSLINK, SERIAL1) and the external devices (XIL) are at the end of the loop. So your instrument is not at address 1 (the default address used by OUTA/INA) and you must first SELECT it. The recommended way is to use the FINDID command and the ID of your instrument that is LMI2200-12 according to the manual you provided elsewhere: "LMI2200" (use the first 7 characters only) FINDID SELECT then you can do the required OUTA/INA sequences. Quote:Also strange thing, when activating ALPHA and typing command to send(before OUTA)- some symbols become *, some not, and they are in lower register(not sure if it matters), so maybe I'm not actually sending correct commands to device? This is because emu41p, by default, load the excellent CCD-OSX ROM (a subset of the CCD module) that provides access to the full lowercase characters. You can either remove the CCD-OSX ROM in the emu41p.ini file, or just disable the lowercase feature by using the USER mode. J-F RE: emu41p + HP-IL - S0N1C - 10-22-2018 07:29 PM Yep, it did it! It is device #5 on the loop, and now it responds to my commands Thank you Sylvain Cote and J-F Garnier! RE: emu41p + HP-IL - S0N1C - 10-22-2018 07:57 PM Just to show how it looks |
