Storing and recalling CAS quoted expressions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Storing and recalling CAS quoted expressions (/thread-11624.html) |
Storing and recalling CAS quoted expressions - BruceH - 10-21-2018 01:29 PM In the CAS, if I do Code: a:='2+2' does a now store 4 or '2+2'? Is there a way of telling? If the latter, is there a way of recalling the original '2+2' rather than 4? RE: Storing and recalling CAS quoted expressions - nbenm - 10-21-2018 01:33 PM (10-21-2018 01:29 PM)BruceH Wrote: In the CAS, if I do Hi, I'm not sure but it seems that: 1 - a:='2+2' stores 4 2 - a:="2+2" stores the string 2+2 RE: Storing and recalling CAS quoted expressions - Tim Wessman - 10-21-2018 01:49 PM I believe any simple evaluations such as basic math will be evaluated by the store operator. Anything more complex will not. RE: Storing and recalling CAS quoted expressions - parisse - 10-21-2018 06:02 PM You can control evaluation with the second optional argument of eval. For example a:='2+2' followed by eval(a,1) will return 2+2, assuming that auto-simplification level is 0. RE: Storing and recalling CAS quoted expressions - BruceH - 10-23-2018 10:40 PM Thanks Bernard. |
