Invalid Card Data startup error on HP48GX - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Invalid Card Data startup error on HP48GX (/thread-1169.html) |
Invalid Card Data startup error on HP48GX - John W Kercheval - 04-25-2014 12:04 PM Hello: My HP 48GX is giving me an error on startup called "Invalid Card Data." The card plugged in the an (empty) 1MB expansion card from HP. How do I fix this? Any ideas? thanks, John RE: Invalid Card Data startup error on HP48GX - Han - 04-25-2014 12:45 PM Use the PINIT command. If even after using the PINIT command you are still getting Invalid Data upon turning the calculator on, then I recommend changing the card's battery. RE: Invalid Card Data startup error on HP48GX - John W Kercheval - 04-25-2014 07:14 PM Thanks! PINIT worked. John in West LA RE: Invalid Card Data startup error on HP48GX - John Galt - 01-23-2015 10:14 PM Anyone finding this topic by searching this site might like to know I encountered this same error on an HP50g (not mine). Other than the SD card slot, there are no card options on that model. There was no SD card inserted. Interestingly enough PINIT made it go away as well. Ciao. |
