Helix Arc Length - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Helix Arc Length (/thread-11868.html) |
Helix Arc Length - ArPEn - 11-29-2018 02:56 AM Would someone mind demonstrating how to calculate the arc length of a helix, or show how to integrate over a 3D vector on the HP Prime? I am attempting to calculate the length of wire required to wrap around a cylinder, and need to mathematically determine length to calculate resistance. Parameters: Height: 10 inches Revolutions: 35 Diameter: 0.54 inches Pitch: 0.29 inches A=∫(from 0 to 1)? √((x′(t))^2+(y′(t))^2+(z′(t))^2) dt (Taken from https://math.stackexchange.com/questions/2160851/finding-the-length-of-a-helix) If anyone is able to direct me how to integrate over a 3D vector function I can probably figure out the correct formula and/or inputs. I just can't figure out how to input the equation properly. Thanks kindly! RE: Helix Arc Length - ijabbott - 11-29-2018 08:45 AM Hint: a cylinder is flat if you unroll it. So for a single turn, the length is SQRT((2*PI*R)^2 + L^2), where R is the radius of the cylinder (helix) and L is the longitudinal separation (or "lead") between turns. Multiply by the number of turns N for the total length. EDIT: Since you mentioned the diameter, you can of course replace 2*PI*R with PI*D in the above. Or if 'D' is the inner diameter of the helix, and 'W' is the diameter of the wire, you can use PI*(D+W) RE: Helix Arc Length - Nigel (UK) - 11-29-2018 09:22 AM ...or, if you want to do it by integration, parameterise the curve as \[x=r\cos\theta\qquad y=r\sin\theta\qquad z={l\over2\pi}\theta\] where \(r\) is the radius and \(l\) is the distance between one turn and the next. The square root in your integral is \[\sqrt{r^2+{l^2\over 4\pi^2}}\] which is a constant. Integrate over \(\theta\) from \(\theta=0\) to \(2\pi\) and you get the length of one turn; then multiply by the number of turns. Nigel (UK) RE: Helix Arc Length - ArPEn - 11-30-2018 03:10 AM Would you be able to demonstrate how to enter this into the calculator? I am unable to determine how to actually enter these into the calculator. |
