hp 48 batteries - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: hp 48 batteries (/thread-11899.html) |
hp 48 batteries - Marcelo Vanti - 12-03-2018 05:53 PM Hi all, Recently the batteries of my 48 leaked, and calculator became irresponsible. As I had been wanting for some time, I was able to buy another, almost brand new, manufactured in 1997 (I'm very happy) . now, I'm afraid of a new battery leak. The only solution to this is to keep the calculator without the batteries? In this case, I will lose the settings, and I will have to hit everything with each use. Is there any solution to keep the batteries in the calculator so they do not leak? Thanks for any advice, RE: hp 48 batteries - EugeneNine - 12-03-2018 06:44 PM Nearly any battery can leak. Just make a habbit to replace once a year. If you swap them quick enough the capacitor inside keeps the memory intact. Also make a backup to your computer first. RE: hp 48 batteries - SammysHP - 12-03-2018 06:46 PM NiMH (preferably LSD version like Eneloop) will usually not leak. It might vent if you over(dis)charge them, but that won't happen in the calculator. RE: hp 48 batteries - EugeneNine - 12-03-2018 10:14 PM I've had a couple no name and radio shack NiMH leak. But Eneloops I've used since they came out over 10 years ago. I do pull them out of everything and top them off at regular intervals . RE: hp 48 batteries - HP67 - 12-04-2018 10:21 PM (12-03-2018 05:53 PM)Marcelo Vanti Wrote: Hi all, Sorry to hear this. I had a battery leak in an old (irreplaceable) Palm Pilot. It was Duracell, my first Duracell leak in 30 years. Since then I use only Lithium disposables (expensive!) or recently, Eneloops. I understand they cannot leak. I really don't know but I hope they can't. RE: hp 48 batteries - Marcelo Vanti - 12-05-2018 03:34 PM Thank you guys. At first, the best thing to do is to change the batteries periodically, as was suggested. I will also test a set of Lithium batteries, should not leak, as I read here and elsewhere. RE: hp 48 batteries - EugeneNine - 12-05-2018 05:33 PM Are all HP's safe with the higher voltage of Lithium's? RE: hp 48 batteries - Marcelo Vanti - 12-05-2018 05:40 PM (12-05-2018 05:33 PM)EugeneNine Wrote: Are all HP's safe with the higher voltage of Lithium's?Good question, I've read somewhere that the voltage can reach 1.9 V, I do not know the impact on the calculator. RE: hp 48 batteries - EugeneNine - 12-05-2018 11:25 PM Also I forgot to mention that, even though I've never had an eneloop leak I have had NiMH leak so it seems to me that its possible. Thats why I swap mine out every so often. Buy two packs and make a schedule, say every time change to put the charged in and put charge the ones that were in the calculator. RE: hp 48 batteries - HP67 - 12-06-2018 09:28 PM (12-05-2018 05:33 PM)EugeneNine Wrote: Are all HP's safe with the higher voltage of Lithium's? The ones I buy say 1.5V on the package. RE: hp 48 batteries - RMollov - 12-07-2018 08:29 AM Leakage doesn't ruin calculator immediately, it takes time - months at least until bad things happen. So yearly check should be enough. Answer to 'which brand batteries never leak' is similar to 'which type/make cars never crash'. |
