CAS/Home buggy - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: CAS/Home buggy (/thread-11908.html) |
CAS/Home buggy - toshk - 12-05-2018 11:09 PM #pragma mode( separator(., integer(h32) ) EXPORT zlines(ybuss) BEGIN local lnedata,linedat,ttalbuses,zp; local a,b,c,d,q,M11; ttalbuses:= SIZE(mat2list(col(ybuss,1))); a:=col(ybuss,1); lnedata:=transpose(ybuss); linedat:=sum(lnedata); b:=length(linedat); return ({ttalbuses,a,lnedata,linedat,b}); END; Home run; zlines([[0.166666666667,−0.166666666667,0],[−0.166666666667,0.277777777778,−0.111111111111],[0,−0.111111111111,0.311111111111]]) correct answer={3,[0.166666666667,−0.166666666667,0],[[0.166666666667,−0.166666666667,0],[−0.166666666667,0.277777777778,−0.111111111111],[0,−0.111111111111,0.311111111111]],[0,0,0.2],3} CAS run; zlines([[0.166666666667,−0.166666666667,0],[−0.166666666667,0.277777777778,−0.111111111111],[0,−0.111111111111,0.311111111111]]) buggy answer={50,'tran',tran(ybuss),"prodsum Error: Bad Argument Value",1} ?? RE: CAS/Home buggy - toml_12953 - 12-06-2018 02:31 AM (12-05-2018 11:09 PM)toshk Wrote: #pragma mode( separator(., integer(h32) ) Your semi-colon followed by a right parenthesis looks like a winking smiley face when rendered by this forum! ; ) RE: CAS/Home buggy - grsbanks - 12-06-2018 08:43 AM Place the lot in "code" tags and that should solve the problem: Code: #pragma mode( separator(., ;, integer(h32) ) |
