12C Platinum and Store Registers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 12C Platinum and Store Registers (/thread-11953.html) |
12C Platinum and Store Registers - Gamo - 12-15-2018 01:12 PM Recently I wrote a program on 12C Platinum that used 260 steps and 16 store registers. With this many steps and use a lot of store memory this12C Platinum still be able to run this program no problem at all. This make the user not to worry about program capacity at all when writing very long program. No need to adjust Memory Reallocation like the 15C Gamo RE: 12C Platinum and Store Registers - Don Shepherd - 12-15-2018 07:30 PM (12-15-2018 01:12 PM)Gamo Wrote: Recently I wrote a program on 12C Platinum thatHi Gamo. I don't know if HP fixed it, but there was a bug in some of the early 12-cp's (Platinum) regarding the GOTO command. If the line number of the GOTO destination was greater than some number (which I can't remember), the GOTO would generate an error. I discovered this when I tried to load up all those 400 steps and store several programs at once. I wrote HP about this and they agreed it was a bug. Maybe they fixed it, but maybe not. RE: 12C Platinum and Store Registers - Gene - 12-16-2018 02:17 AM Think they did fix it. I Think it was GTO 254 or higher? Maybe 255. RE: 12C Platinum and Store Registers - Gamo - 12-16-2018 02:44 AM Don Shepherd Thanks to mention about GOTO bug. Luckily my program didn't use any GOTO in this program but good to know that there is a GOTO bug if I use this in future this will keep me notice. Side Note on personal experience: I own 12C (Made in China) serial number CNAxxxxRF9 12C (Made in Philippines) serial number PHAxxxxxxV The 12C keys respond is not good compare to 12C Platinum. The 12C the #4 keys always have problem either once press it miss or double entry. So far no problem at all on the Made in Philippines version. Gamo |
