(HP-97) Stability Design of Grass-Lined Open Channels - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-65/67/97 Software Library (/forum-12.html) +--- Thread: (HP-97) Stability Design of Grass-Lined Open Channels (/thread-12104.html) |
(HP-97) Stability Design of Grass-Lined Open Channels - SlideRule - 01-05-2019 01:34 PM An extract from the ABSTRACT of Stability Design of Grass-Lined Open Channels, Agriculture Handbook Number 667 (USDA), SEP 1987. This handbook presents the state of the art in grass-lined channel design. It is intended primarily for use by engineers and technicians directly involved in planning, designing, or maintaining open channels where vegetation can be used as a lining for erosion protection. Each of the six chapters is a complete discussion, with reference to other chapters as appropriate. Nomographs and calculator/computer programs are included as design aids. Only those design conditions that have implications unique to the use of grass as a channel lining are discussed in detail, and the design aids focus on stability design under steady, uniform flow conditions. Appendixes _A. Variable definitions _B. Calculator/computer routines .... Section 1. Two-dimensional flow approximation for HP-97/67 .... Section 3. Iterative design of trapezoidal channels for HP-97/67 .... Section 5. Iterative design of parabolic channels for HP-97/67 BEST! SlideRule |
