(11C) Seismic Reflection Methods Applied to Engineering, Environmental & Groundwater - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (11C) Seismic Reflection Methods Applied to Engineering, Environmental & Groundwater (/thread-12125.html)
(11C) Seismic Reflection Methods Applied to Engineering, Environmental & Groundwater - SlideRule - 01-07-2019 02:22 AM
An extract from Seismic Reflection Methods Applied to Engineering, Environmental, and Groundwater Problems, Kansas Geological Survey, KU (Lawrence, KS).
… determine the seismic velocity within the materials penetrated by the reflected seismic waves. The simplest procedure with good seismic-reflection data is to fit a hyperbola to the data using a least-squares approach. Table 1 shows a simple program for a HP11C or HP15C calculator that will calculate seismic velocity for such a case. The user simply inputs two or more time-distance pairs of numbers from a reflection on the field record or from the CDP gathers to calculate a seismic velocity. The program also calculates the reflection time for the zero-offset distance for the hyperbola …
Table 1.
Shown is a program that will run on either an HP 11C or HP 15C pocket calculator. The program (1) uses two or more time-distance pairs (distance treated as x and time as y) measured from a field seismogram as input data; (2) performs an hyperbolic least-squares fit of the data, assuming the time-distance pairs are picked from a true reflector; (3) calculates, stores, and displays zero-offset reflection time (TO), velocity (Vnmo), depth to reflecting interface (z), and correlation coefficient (r). The program assumes flat-lying as opposed to dipping reflectors …
BEST!
SlideRule
