(50g) Outer Product, Kronecker Product - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (50g) Outer Product, Kronecker Product (/thread-12487.html)
(50g) Outer Product, Kronecker Product - John Keith - 02-23-2019 03:14 PM
Inspired by this thread, I am posting two programs for the 50g.
The first program, which will also run on the 48G, computes the outer product of two vectors or the Kronecker product of two matrices.
\<< SWAP DUP2 SIZE SWAP SIZE +
  IF DUP SIZE 2. SAME
  THEN EVAL 4. ROLL SWAP 1. SWAP 2. \->LIST RDM UNROT 1. 2. \->LIST RDM SWAP *
  ELSE EVAL \-> a m n p q
    \<< DUP m p * n q * 2. \->LIST RDM 1. m
      FOR i 1. n
        FOR j OVER a i j 2. \->LIST GET * i 1. - p * 1. + j 1. - q * 1. + 2. \->LIST SWAP REPL
        NEXT
      NEXT NIP
  END
The next program computes the "generalized outer product" of two vectors. Level 1 should have a program which takes two arguments. Levels 2 and 3 should have vectors, which need not be the same size. The output will be a matrix whose elements result from the function being applied to corresponding elements of the input vectors.
For example, if the function is \<< * \>> the result will be the outer product of the two vectors.
\<< SWAP AXL PICK3 SIZE EVAL OVER SIZE \-> c f r cs rs
  \<< 1. cs
    FOR j c j GET rs NDUPN \->LIST r 2. f DOLIST
    NEXT cs \->LIST AXL
