Equation stored in variable, then used by Solver - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Equation stored in variable, then used by Solver (/thread-1249.html) |
Equation stored in variable, then used by Solver - Alfon - 05-05-2014 10:59 PM Is there a way to store an equation in a variable, then use the solve application to retrieve this equation from the variable and then solve it? RE: Equation stored in variable, then used by Solver - Han - 05-06-2014 01:08 AM You can save the equation in a string. Likewise, I would consider a separate string for the variables. E.g. Code:
These routines can easily to combined into a solver app to build an actual equation library with complete support for custom equations and variables. I'm currently working on one, but have been sidetracked with several other projects… RE: Equation stored in variable, then used by Solver - Angus - 05-06-2014 07:17 AM Han, is that part of program code? What did you show? How would you use it? Do you -have- to store equations to a global, capitalized variable F? Do you assign the variable list m,a and the equation prior to program start? A working example with additional comments would be beneficial. Thanks. RE: Equation stored in variable, then used by Solver - CR Haeger - 05-06-2014 12:03 PM I have saved formulas into CAS variables, defined solve.E1:='CAS variable' (a formula) then used Solver. Here is a thread about this: http://www.hpmuseum.org/forum/thread-955.html Best, Carl RE: Equation stored in variable, then used by Solver - Angus - 05-06-2014 12:15 PM Thank you, I remember your thread. You don't use any strings, I see? Copying over a note to the cas is not really user friendly. :-( I had the feeling Han tried to add more automation on the one hand and on the other I feel like that is an example to learn to avoid issues when programming the calculator. What is about string usage and no string usage. I studied the patch notes and did not notice any changes concerning these topics (that is data handling) so there is a need to get used to how things are now. They are likely to last..... I might be old or I might not have enough time for the calculator there is even the chance of being too stupit, but I did not really understand this device. I can play with it, I find interessting aspects, but once I really need it I get stuck and can't find the right way to work with it. It still did not become a tool, it is still a toy which frustrates me. |
