Matrix power limit - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Matrix power limit (/thread-12515.html) |
Matrix power limit - Albert Chan - 02-27-2019 03:28 PM I am not sure about HP Prime, but XCas 1.4.9-57(win32) had a matrix power 31 bits limit. Example: Perrin Primality test qpowmod(n) := ([[0,1,1],[1,0,0],[0,1,0]] % n) ^ (n-1) perrin(n) := dot(qpowmod(n)(2), [2,0,3]) == 0 map(range(2, 10), x -> x * perrin(x)) ==> [2, 3, 0, 5, 0, 7, 0, 0] However, the code will not work for n > 2^31 perrin(9876543211) ==> "Abs Error: Bad Argument Type" To fix it, need another matpow version that can handle bigger n: matpow2hlp(a, n, half) := ifte(odd(n), a*half, half) * half matpow2(a, n) := ifte(n<2^31, a^n, matpow2hlp(a, n, matpow2(a, n div 2))) qpowmod2(n) := matpow2([[0,1,1],[1,0,0],[0,1,0]] % n, n-1) perrin2(n) := dot(qpowmod2(n)(2), [2,0,3]) == 0 perrin2(9876543211) ==> true Update: it seems the limit is not really due to matrix power, but the modulo. RE: Matrix power limit - Joe Horn - 02-27-2019 05:51 PM HP Prime in CAS view: [[1]]^(2^8198) --> [[1]] [[1]]^(2^8199) --> undef |
