Bulding an RPN Calculator - Printable Version
+--- Thread: Bulding an RPN Calculator (/thread-12667.html)
Bulding an RPN Calculator - pcardoso73 - 03-23-2019 12:51 AM
Dear all,
As all of us, I am an RPN and hp calculator lover. My day to day calculator is an HP 48G, but now I need something larger with big keys (aging vision problems, so big keys = big letters and numbers).
After searching a bit, I could not find a big RPN calculator. So, in order to get a big, inexpensive RPN calculator, I would have to build one. Cool !
I started by looking for the perfect calculator. It must be thick enough to fit hardware inside and large enough so could have big keys.
I ended up and buying a 5£ desktop calculator off eBay. The idea was to strip everything inside, replace the original LCD by a two-line LCD and control everything with an Arduino. :-)
In the beginning I thought that I would touch only the LCD (single line and 12 digit and I needed two lines) and keep all the rest, but things didn't go that way.
The keyboard is a simple membrane keyboard. Unfortunately, the acetate sheet that has the tracks painted is glued to a pcb (not soldered), so it is not reusable. When trying to remove it, it became unusable.
Because of this I made a PCB for the membrane keyboard and it works! :-)
Until now, these are the materials used for this project:
1 Desktop calculator
1 LCD 24 x 2 display
1 Arduino nano
1 Custom PCB
1 battery (to be decided, but I might use a single cell powerbank).
and lots of wires
At this point the calculator is not yet assembled, but the arduino, keyboard and lcd are working.
If you like, I can give your more details as the project progresses.
I hope this post wasn’t too boring. ?
Best regards,
Pedro
RE: Bulding an RPN Calculator - jackrubin - 03-23-2019 02:53 AM
Yes, of course - more please!
RE: Bulding an RPN Calculator - Carsen - 03-23-2019 03:57 AM
Yeah. This is rather cool! I would love to hear more, especially with what you are going to do with the keyboard layout. And...
Welcome to the Museum!
RE: Bulding an RPN Calculator - Paul Dale - 03-23-2019 05:19 AM
Nice project.
Are switches a possibility? The tactile feedback is worth a lot (to me).
I worked with someone who soldered one of those flex sheets to fix an HP 30B of mine. I'd have ended up with a blob of plastic (if I managed to avoid vapourising it).
Have fun with the software!
Pauli
RE: Bulding an RPN Calculator - BobVA - 03-23-2019 06:50 PM
Brilliant and welcome aboard! Yes, please do keep us posted.
RE: Bulding an RPN Calculator - Eddie W. Shore - 03-26-2019 01:58 PM
Not at all Pedro, in fact, quite the opposite. Please keep posting progress on your RPN calculator. Wishing you much success!
Eddie
RE: Bulding an RPN Calculator - toml_12953 - 03-26-2019 04:54 PM
(03-23-2019 12:51 AM)pcardoso73 Wrote:  At this point the calculator is not yet assembled, but the arduino, keyboard and lcd are working.
Best regards,
Pedro
More details, please! Also, does that = key work as ENTER now?
RE: Bulding an RPN Calculator - pcardoso73 - 04-02-2019 10:20 PM
Thank you all for your kind words.
Quote:Also, does that = key work as ENTER now?
Actually the key which will be the ENTER is the big + key. I thought that the ENTER should be large, hence the choice.
Regarding the development, nothing happened this week. Today I received a hot glue gun and a set of metal files. I have ordered the files since the calculator's case doesn't close where the LCD is. Fortunately, it has some slots that can be filed down.
Then I will use hot glue to put everything in its proper place.
But before closing the calculator, I will have another problem to solve:
  • the type of battery
  • how to connect it
  • single or dual power?
  • do I use the coin cell that came with the calculator ?
The last reminds bullet makes me laugh, because it reminds me when I opened the calculator for the first time. Despite saying that the calculator is dual powered, the solar cell is fake and instead, they put inside a coin cell. :-)
Soon I will post some more photos and details.
Thanks.
Cheers,
Pedro
