Re-integration problem of abstract function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Re-integration problem of abstract function (/thread-12784.html) |
Re-integration problem of abstract function - yangyongkang - 04-11-2019 12:44 PM Recently I tried to solve the re-integration of some abstract functions with xcas and found some problems.for example: Code: diff(integrate(integrate(f(sqrt(x^2+y^2)),y,-(sqrt(t^2-x^2)),sqrt(t^2-x^2)),x,-t,t),t) Code:
Related issues Code: ∫(∫(e^(-(x^2+y^2)/2),y,-(sqrt(a^2-x^2)),sqrt(a^2-x^2)),x,-a,a) Code: integrate(sqrt(pi)*1/(sqrt(2))*erf(sqrt(a^2-x^2)*exp(ln(2)/2)/2)*exp(-x^2/2)-sqrt(pi)*1/(sqrt(2))*erf(-sqrt(a^2-x^2)*exp(ln(2)/2)/2)*exp(-x^2/2),x,-a,a) In fact, we can get the correct answer through polar transformation. Code: ∫(∫(e^(-r^2/2)*r,r,0,a),x,0,2π) Code: 2*pi*(-exp(-a^2/2)+1) Looking forward to the update of hp prime firmware in 2019 RE: Re-integration problem of abstract function - yangyongkang - 04-25-2019 12:20 PM Let's take a look at this issue. RE: Re-integration problem of abstract function - Eddie W. Shore - 04-30-2019 07:30 PM My only suggestion is to try integration and differentiation one step at a time (inside out). Patience may be needed. I don't know if turning complex mode off in CAS would help. Eddie. RE: Re-integration problem of abstract function - Hans S. - 04-30-2019 08:25 PM (04-11-2019 12:44 PM)yangyongkang Wrote: Recently I tried to solve the re-integration of some abstract functions with xcas and found some problems.for example:brings to mind chinese figure skaters (f.) or the so-called pianist lang lang: indefinite exercise, no (artistic) result. H. |
