Way to connect 50g to 48? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Way to connect 50g to 48? (/thread-1279.html) |
Way to connect 50g to 48? - HP67 - 05-09-2014 03:12 PM The IR connection isn't compatible between these two devices. Is there a standard cable that will work between a 50g and a 48? Has anybody looked into what would be required to get a 50g and a 48 to talk over IR? RE: Way to connect 50g to 48? - Egan Ford - 05-09-2014 05:25 PM Serial. RE: Way to connect 50g to 48? - walter b - 05-09-2014 05:29 PM (05-09-2014 05:25 PM)Egan Ford Wrote: Serial. Serially. SCNR RE: Way to connect 50g to 48? - Marcus von Cube - 05-10-2014 06:43 PM It's serial but it's not a straight connection but needs a level shifter instead. I found two articles that describe the port and a cable for both devices: HP 48G: http://www.hpcalc.org/hp48/docs/faq/48faq-12.html HP 50G: http://www.allenwan.com/hpcalcserialcable/ Some soldering required... RE: Way to connect 50g to 48? - Michael Lopez - 05-11-2014 01:49 AM Alternatively, you can buy a suitable pre-made serial cable from Eric at hpcalc.org (see http://commerce.hpcalc.org/ ). This is what I did & it works fine. Cheers, Michael RE: Way to connect 50g to 48? - HP67 - 05-11-2014 05:51 AM Thanks for the links, Marcus. Bookmarked! Michael, I see a serial cable for the 50g on hpcalc but I don't see a cable that would work between a 50g and a 48. Did I miss something, or did you mean if I get the 50g cable it will work with a stock 48 cable? Thanks. What about IR between the 50g and the 48? Has anybody looked into it? (no pun intended). RE: Way to connect 50g to 48? - Michael Lopez - 05-11-2014 09:32 AM Hi HP67, The cable you need to purchase is the one called: "HP 50g RS-232 Serial Cable". Then you plug the old standard HP48 serial cable (HP type or other) into the 9 pin D-Plug end of this new cable resulting in suitable connections at both ends for the HP50G & HP48 series calculators. Just be aware also that the transfer must be performed in ASCII Kermit mode & it is only safe to transfer standard User RPL programmes & functions. If you try to transfer System RPL programmes & functions you will crash one or both calculators due to the differences in internal addressing etc. Cheers, Michael RE: Way to connect 50g to 48? - HP67 - 05-11-2014 09:39 AM Thank you, I will get one of those. Sounds very convenient! RE: Way to connect 50g to 48? - Marcus von Cube - 05-11-2014 10:11 AM (05-11-2014 09:32 AM)Michael Lopez Wrote: The cable you need to purchase is the one called: "HP 50g RS-232 Serial Cable". Then you plug the old standard HP48 serial cable (HP type or other) into the 9 pin D-Plug end of this new cable resulting in suitable connections at both ends for the HP50G & HP48 series calculators.Are you sure you can just plug them together? If both are targeted at a PC com port you'll need a null modem with two 9 pin male connectors as an adapter. EDIT: I stand corrected! Here is the description of Eric's cable: Quote:Our cable has a standard male 9-pin connector for connecting directly to serial devices with no gender changer needed. While it is possible to connect it to a computer by using a null modem adapter, we feel that most users would prefer to use a USB cable for a PC link, allowing us to not need an adapter when connecting to serial devices.So no null modem required. RE: Way to connect 50g to 48? - HP67 - 05-11-2014 10:17 AM The 50g cable at the HPCalc site seems to have the right gender to match the standard 48 cable. Part of the info there says "Our cable has a standard male 9-pin connector for connecting directly to serial devices with no gender changer needed. While it is possible to connect it to a computer by using a null modem adapter, we feel that most users would prefer to use a USB cable for a PC link, allowing us to not need an adapter when connecting to serial devices." http://commerce.hpcalc.org/serialcable.php This looks ok, but I really don't know. RE: Way to connect 50g to 48? - Michael Lopez - 05-11-2014 12:29 PM Hi all, I've been using Eric's cable for a couple of years & can confirm the standard HP48 cable plugs straight in without using a null modem or any other device. If I get a chance this week, I'll post a photo showing how they fit together without modifications of any kind. Once the cables are connected together & you set-up the communication on both calculators to serial etc, it works flawlessly. Cheers, Michael RE: Way to connect 50g to 48? - HP67 - 05-11-2014 12:48 PM Thanks again. This looks like a great suggestion and a great product. |
