HP41CX for Android and ES-41 Eramco Box - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: HP41CX for Android and ES-41 Eramco Box (/thread-12845.html) |
HP41CX for Android and ES-41 Eramco Box - thomasgarnold - 04-22-2019 02:30 AM The Hp41cx for android app is a masterpiece. But I desperately need help with a compatibility problem with eramco es-41 ram. . I cannot load the ram 8K 16k ROM modules properly. These are Furlow's mod files and work properly on his pc emulator. His PC version accesses the es41 op system which is 8k in system as is but the mod file is actually 11k in size. LIkewise, the ram16k.mod file is actually 21k. Therefore, Furlow's calculator allows 32K to be accessed although the files are actually 42K. There are two rom files in each mod file and I suspect the extra rom file is to allow read and write functions to the ram. Is it at all possible to allow this in your android emulator? Right now I am limited to 24K since the actual size of files in 32K. Does anyone have any idea how to solve this. I really would appreciate any help you can give me. |
