Solver: Length of a V Belt - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Solver: Length of a V Belt (/thread-12932.html) |
Solver: Length of a V Belt - Eddie W. Shore - 05-06-2019 11:40 AM Blog Entry: http://edspi31415.blogspot.com/2019/05/hp-prime-and-hp-42sdm42free42-length-of.html The following equation relates the length of a V belt, the center to center distance between two pulleys or sheaves: L = 2 * C + 1.57 * (D + d) + (D - d)^2/(4 * C) where: L = length of the V belt, the belt that wraps around two pulleys (or sheaves) C = center to center distance D = diameter of the large pulley/sheave d = diameter of the small pulley/sheave HP Program VBELT This program creates four global variables: beltlength = L centerdist = C lrgpulley = D smpulley = d The program then takes you to the Num page of the Solve app. This allows us to create descriptive variables to help us in the Solve app. Global variables are created outside the main program. Code: // create global variables Example 1: Large Pulley Diameter = 1 in Small Pulley Diameter = 3/4 in Center to Center Distance = 1.5 in Result: V Belt Length ≈ 5.7579 in Example 2: Large Pulley Diameter = 1 in Small Pulley Diameter = 7/16 in V Belt Length = 6.24 in Result: Center to Center Distance ≈ 1.975 in Source: Gladstone, John "Air Conditioning Testing and Balancing: A Field Practice Manual" Van Nostrand Reinhold Company: New York. 1974 ISBN 0-442-22703-5 |
