Classic Schematics - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Classic Schematics (/thread-13065.html) |
Classic Schematics - teenix - 06-04-2019 08:00 AM Hi all, If anyone is interested, I uploaded some schematics of the classics and HP67 in PDF format. I have left out the logic interconnections as to me they complicate matters, however all connections are marked. http://www.teenix.org/classSchm.zip cheers Tony RE: Classic Schematics - Harald - 06-04-2019 09:22 AM Tony, Thanks a lot for the effort and for making these avaialble! Cheers, Harald RE: Classic Schematics - PANAMATIK - 06-04-2019 10:48 AM Thanks teenix I love classic schematics! Bernhard RE: Classic Schematics - DaveBr - 06-04-2019 01:14 PM Thank you! RE: Classic Schematics - [kby] - 06-04-2019 10:36 PM Thank you! RE: Classic Schematics - teenix - 06-10-2019 04:29 PM Hi all, I added schematics for HP-10 and HP-19C in PDF format to the zip file. http://www.teenix.org/classSchm.zip cheers Tony RE: Classic Schematics - Peter Monta - 06-10-2019 11:47 PM Thanks---very useful and readable. On the HP-35 schematic, pins 15 and 17 of the 26-pin header have the same label, C3. One of them should be C4 I guess. RE: Classic Schematics - teenix - 06-11-2019 12:38 AM (06-10-2019 11:47 PM)Peter Monta Wrote: Thanks---very useful and readable. On the HP-35 schematic, pins 15 and 17 of the 26-pin header have the same label, C3. One of them should be C4 I guess. Thanks Peter, Fixed. There are probably other bugs there that I missed. I'm sure sometimes when I see an error, my mind totally ignores it for some reason. Maybe my blind spot is bigger than I think. Recently, and after numerous checks, I put in a new PCB design for the replacement HP-67 CPU board and as soon as I got the message it was completed and on it's way I saw a circuit error :-( Thankfully nothing major. cheers Tony RE: Classic Schematics - Jim Horn - 06-11-2019 12:51 AM Thank you for that, Tony! Just a minor point - the HP67 Charger diode bridge is rotated clockwise 90° compared to the actual circuit (the four diodes should be pointing to the top of the 400µF cap). Best to you - and thank you for all your research, hard work and delightful postings! RE: Classic Schematics - teenix - 06-11-2019 01:24 AM (06-11-2019 12:51 AM)Jim Horn Wrote: Thank you for that, Tony! Thanks Jim, (all Classics too) Fixed :-) I put the charger on its own sheet. cheers Tony RE: Classic Schematics - isanchez - 06-13-2019 07:26 AM Impressive! Congrats! Thanks for sharing! Kind regards Ignacio RE: Classic Schematics - [kby] - 06-17-2019 03:34 AM (06-10-2019 04:29 PM)teenix Wrote: Hi all,Thanks for the update! minor point: both the HP-10 and HP-19c are labeled HP-10. -kby RE: Classic Schematics - teenix - 06-17-2019 05:42 AM (06-17-2019 03:34 AM)[kby] Wrote: Thanks for the update! minor point: both the HP-10 and HP-19c are labeled HP-10. All Fixed :-) cheers Tony RE: Classic Schematics - Archilog - 06-17-2019 11:47 PM Many thanks for those helpfull schematics! |
