39gII and UTPT - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 39gII and UTPT (/thread-1336.html) |
39gII and UTPT - kakima - 05-17-2014 06:34 AM UTPT(D,T) for T<0 seems to be returning UTPT(D,ABS(T)). UTPT(20, 0) return 0.5, which is correct. For T=0 you expect half the values to be above that. UTPT(20, 1.6) returns 0.0626, which agrees with every other calculator I've tried. UTPT(20, -1.6) returns the same value, when it should be returning 1 - 0.0626 or 0.9374 which every other calculator I've tried including a 39g+ returns. RE: 39gII and UTPT - Joe Horn - 05-17-2014 03:26 PM (05-17-2014 06:34 AM)kakima Wrote: UTPT(20, -1.6) returns the same value, when it should be returning 1 - 0.0626 or 0.9374 which every other calculator I've tried including a 39g+ returns. I just checked UTPT(20,-1.6) on two HP 39gII's (one is version 27/Aug/2011, and the other is version 19/jan/2012), and both return the correct answer of 0.9374, not the incorrect answer you're getting. Which firmware version do you have? RE: 39gII and UTPT - kakima - 05-17-2014 03:37 PM Remind me how to determine the firmware version. FWIW I got the machine at HHC 2013. RE: 39gII and UTPT - Joe Horn - 05-19-2014 08:33 AM (05-17-2014 03:37 PM)kakima Wrote: Remind me how to determine the firmware version. With the 39gII turned on, press ON, hold it down, then press F4, then release both. This launches the self-test. The firmware version is displayed in the upper left corner. Press 8 to return to normal mode. RE: 39gII and UTPT - kakima - 05-19-2014 12:39 PM Thank you. My firmware is dated 04/Sep/2012 Rev 17818. This is newer than the two you have. Maybe this accounts for some of the other oddities I'm experiencing and my inability to reproduce some of the results others are reporting. RE: 39gII and UTPT - Guenter Schink - 05-19-2014 01:55 PM (05-19-2014 12:39 PM)kakima Wrote: Thank you. My firmware is dated 30/Oct/2013 Rev:19148 It shows the same result as yours. Günter RE: 39gII and UTPT - HP67 - 05-19-2014 02:23 PM How come a discontinued calculator gets new firmware and the 50g is still waiting from 2009!? RE: 39gII and UTPT - Guenter Schink - 05-19-2014 04:14 PM (05-19-2014 02:23 PM)HP67 Wrote: How come a discontinued calculator gets new firmware and the 50g is still waiting from 2009!? Where does this information "the 39gII is discontinued" come from? RE: 39gII and UTPT - kakima - 05-19-2014 04:37 PM (05-19-2014 04:14 PM)Guenter Schink Wrote: Where does this information "the 39gII is discontinued" come from? Perhaps that HP doesn't list it on their website is a clue? RE: 39gII and UTPT - Didier Lachieze - 05-19-2014 05:01 PM (05-19-2014 04:37 PM)kakima Wrote:In France at least it's listed and in stock: Calculatrice graphique HP 39gII.(05-19-2014 04:14 PM)Guenter Schink Wrote: Where does this information "the 39gII is discontinued" come from?Perhaps that HP doesn't list it on their website is a clue? RE: 39gII and UTPT - bhtooefr - 05-19-2014 05:16 PM The 39gII was never intended for the North American market, only Asian and European markets, I thought. RE: 39gII and UTPT - HP67 - 05-19-2014 05:25 PM (05-19-2014 05:16 PM)bhtooefr Wrote: The 39gII was never intended for the North American market, only Asian and European markets, I thought. This appears to be correct. Thanks to you and Jebem. I didn't see it on hp.com and therefore ASSumed it was discontinued. I will have to remember to watch the other sites to see what HP is doing. |
