The calculator I always wanted - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: The calculator I always wanted (/thread-13603.html) |
RE: The calculator I always wanted - john gustaf stebbins - 03-14-2021 11:16 PM Since the limitations are with Symja, I'll readjust my expectations. I'll play with this some more and see if I can come up with better ideas on how to make it work. RE: The calculator I always wanted - vanLudwig - 03-25-2021 02:11 PM I released a new beta today.
RE: The calculator I always wanted - vanLudwig - 03-30-2021 07:52 PM There is still a problem with 1.3.0 that causes a lot of weird crashes. To the best of my knowledge, if you turn off Alternate Answers in 2nd -> MODE it will avoid the crash in all of these scenarios. I'll fix it before final release. RE: The calculator I always wanted - BINUBALL - 03-31-2021 12:13 AM (03-25-2021 02:11 PM)vanLudwig Wrote: I released a new beta today.I want to examine korean translation. How can I do that? RE: The calculator I always wanted - vanLudwig - 03-31-2021 12:24 AM It uses the locale settings from Android. On my phone, that's Settings -> System -> Languages & input -> Language. RE: The calculator I always wanted - BINUBALL - 03-31-2021 01:32 AM I installed beta Acron Calculator, There is some typo I found on first screen. 30 일 무료 평가판 -> 30일 무료 평가판 구성 구독로 이동하여 -> 구성 구독으로 이동하여 ..I think I have to fix so many typos.. RE: The calculator I always wanted - vanLudwig - 03-31-2021 07:21 PM If you're legitimately interested in doing the Korean translation, modifying the resx file is the best way to do it. It's just a simple xml file; you can edit it in any text editor. I gave Demosthenes lifetime subscriptions for up to 5 people for doing the German translation. I would gladly do the same for you. RE: The calculator I always wanted - BINUBALL - 03-31-2021 11:51 PM One question, where is ModePage_ComplexLabel? I got into 2nd - MODE and I can't find any complex mode. There is also bug that crashes app, first set approx mode and press 2 + 3 2nd 9 ENTER. Click answer 2+i*3 DEG->DMS. It crashes. RE: The calculator I always wanted - vanLudwig - 04-01-2021 12:17 AM I haven't gotten around to implementing polar complex numbers (I think there's also strings for polar vectors in ModePage). I suppressed them in the UI until I decide to implement the functionality. I don't see a crash doing deg->dms in Approx. I'm assuming you have your device in Korean? Does that use a period or a comma as the decimal? RE: The calculator I always wanted - BINUBALL - 04-01-2021 12:31 AM (04-01-2021 12:17 AM)vanLudwig Wrote: I haven't gotten around to implementing polar complex numbers (I think there's also strings for polar vectors in ModePage). I suppressed them in the UI until I decide to implement the functionality.Set Decimal Format digit beyond 15, (ex. 21 digits) and enter 2+3i deg->dms. It stopped. It doesn't crash when Decimal Format digit is below 15. RE: The calculator I always wanted - vanLudwig - 04-01-2021 02:36 PM Yep, decimal precision > 15 digits is the key. I'll add it to my todo list. RE: The calculator I always wanted - vanLudwig - 04-07-2021 06:10 PM Version 1.3 was released to the general public yesterday.
RE: The calculator I always wanted - BINUBALL - 04-12-2021 07:02 AM I forgot about translation long day before. I have to start again, so I upload current progress of korean translation. I think it is 40% done. RE: The calculator I always wanted - vanLudwig - 04-13-2021 11:11 PM Looks good so far. Here's some screenshots with your changes in place. |
