Some questions on HP-41 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Some questions on HP-41 (/thread-13635.html) Pages: 1 2 |
RE: Some questions on HP-41 - Sylvain Cote - 09-14-2019 10:54 PM (09-14-2019 08:36 PM)HP67 Wrote: Thank you, Sylvain I had the PIL box site bookmarked but I don't think I knew about the others. I still have no idea what most of this is all about. Is the PIL box a replacement for HP-IL or does it require you to also have an HP-IL box? This is what is needed to use the PIL-Box with an HP-41 Code: HP-41 -> main calculator/computer I would also suggest to look at the HP-IL Compendium RE: Some questions on HP-41 - Garth Wilson - 09-14-2019 11:44 PM (09-14-2019 08:36 PM)HP67 Wrote: @garth yes, a module with some standard card slot would be amazing or to be honest I'd be quite happy with a module that hosted a server like the 48s have which could talk to Kermit over serial... I don't have Kermit capability on my 41 (not directly at least; maybe it could be done) but I do have the FSI164A HPIL-to-RS232 interface converter which is nearly identical to the HP82164A except that the FSI came with two RS-232 channels standard, and optionally up to eight, and optionally battery-powered. I suppose a module could be written to do the Kermit protocol over serial with the __164A. If you have HPIL, you can interface to nearly anything, one way or another. I also have the HP82165A HPIL-to-parallel interface converter, the HP82169A HPIL-to-IEEE488, and the HP92198 HPIL-to-80-column video. My HPIL module has the Extended I/O module built in, so it's a double module. Quote:Quote:Quote:Check the video in the link below, the SD card appears in minute 3:50 approx. Ok, my mistake. I took the first post too literally and went to 3:50, but missed the seconds between 3:40 and 3:50 where it shows him inserting the microSD card. RE: Some questions on HP-41 - HP67 - 09-16-2019 06:00 PM (09-14-2019 10:54 PM)Sylvain Cote Wrote:(09-14-2019 08:36 PM)HP67 Wrote: Thank you, Sylvain I had the PIL box site bookmarked but I don't think I knew about the others. I still have no idea what most of this is all about. Is the PIL box a replacement for HP-IL or does it require you to also have an HP-IL box? Ok, I feel a second mortgage coming on... (09-14-2019 10:54 PM)Sylvain Cote Wrote: I would also suggest to look at the HP-IL Compendium Thanks, bookmarked! RE: Some questions on HP-41 - Sylvain Cote - 09-16-2019 10:34 PM (09-16-2019 06:00 PM)HP67 Wrote: Ok, I feel a second mortgage coming on...You're lucky, I'm on my fourth RE: Some questions on HP-41 - Diego Diaz - 09-20-2019 04:06 AM Hi all. That topic is almost 11 years old... ;-) https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv018.cgi?read=142210 Feasible, but not practical IMHO... ;-/ Cheers! Diego RE: Some questions on HP-41 - Ángel Martin - 09-20-2019 07:25 AM (09-20-2019 04:06 AM)Diego Diaz Wrote: pic is almost 11 years old... ;-) Well, IMHO not because it's been considered before and not implemented that means it has no value... on the contrary, perhaps it's so due to its complexity or difficulty and not on the grounds of its usefulness. So I read in that thread the Meindert was suggesting to show you his prototype , did that ever happen? The functionallity shown on that video is absolutely amazing, read and write, RAW file import, etc... Cheers, ÁM RE: Some questions on HP-41 - MeindertKuipers - 09-20-2019 02:52 PM I actually did make some attempts to revive the project, and today I would do it differently. An SD card in not more complex than USB, given the fact that the microcontroller has libraries for both. A few years back I actually bought a new prototyping board based on a totally different FPGA combined with an ARM processor, with all open source tools, even for the FPGA. A busy job and other priorities made me put this on the shelf, but I will not throw it away, maybe I will do another attempt ... RE: Some questions on HP-41 - Ángel Martin - 09-20-2019 03:39 PM (09-20-2019 02:52 PM)MeindertKuipers Wrote: I actually did make some attempts to revive the project, and today I would do it differently. An SD card in not more complex than USB, given the fact that the microcontroller has libraries for both. A few years back I actually bought a new prototyping board based on a totally different FPGA combined with an ARM processor, with all open source tools, even for the FPGA. A busy job and other priorities made me put this on the shelf, but I will not throw it away, maybe I will do another attempt ... Yes, yes, yes.... what can we do to sway you to do it?? ;-) RE: Some questions on HP-41 - MeindertKuipers - 09-23-2019 04:43 PM (09-20-2019 03:39 PM)Ángel Martin Wrote:(09-20-2019 02:52 PM)MeindertKuipers Wrote: I actually did make some attempts to revive the project, and today I would do it differently. An SD card in not more complex than USB, given the fact that the microcontroller has libraries for both. A few years back I actually bought a new prototyping board based on a totally different FPGA combined with an ARM processor, with all open source tools, even for the FPGA. A busy job and other priorities made me put this on the shelf, but I will not throw it away, maybe I will do another attempt ... Just give me time ... RE: Some questions on HP-41 - Ángel Martin - 09-24-2019 09:34 AM (09-23-2019 04:43 PM)MeindertKuipers Wrote: Just give me time ... Deal ! ;-) RE: Some questions on HP-41 - HP67 - 11-25-2019 07:58 PM (09-12-2019 09:59 PM)Gene Wrote: Not an endorsement of ebay or the seller (who I do not know), but search for item 133008715082 and you will see one of two original overlays that HP included with the HP-41C. The other overlay included looked exactly like this one but did not have any of the shifted functions present. A very generous forum member sent me 5 overlays in the mail from America to Europe! Thank you DaveBR! |
