[my dead 50g] Is alive!! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: [my dead 50g] Is alive!! (/thread-13698.html) |
[my dead 50g] Is alive!! - Claudio L. - 09-23-2019 12:37 AM Finally, I was able to resurrect my 50g which suffered from accidental boot loader overwrite. For the record, I used a Bus Blaster with the openocd config file shown below. I had a lot of trouble halting the CPU because I did not connect any of the nRST or sRST lines. The last line catches all exceptions and halts, hence it halted due to "invalid instruction" because the flash was empty. Once halted, I was able so simply use the command "flash write_image ..." to send a complete flash image from x49gp. It did not work, failed with some errors I didn't understand but... when I did a memory dump (mdw comand), I realized it actually had programmed more than the 16 kbytes of the boot loader. So it was a partial success, I wasn't able to write the complete image and I can't honestly say what went wrong, but knowing the whole bootloader went in, I simply power-cycled the calc with + and - and got the message on the screen. From there I flashed newRPL from my SD card and my calculator is back to life. Of course, it suffered some permanent changes: * I lost the white rubber that pushes the reset button, it fell on the floor when I was trying to put it in the right position to close the calc and I couldn't find it. * Of course, my calc now has a JTAG cable coming out of the side with a phone cable jack (I know, not ideal but I used whatever I had handy). * The serial number was lost forever, since my calc didn't have the sticker in the back. Now it uses the generic serial number from x49gp. But I'm happy with the results... now I'm tempted to use the Bus Blaster with a Prime... Code:
RE: [my dead 50g] Is alive!! - pier4r - 10-06-2019 06:47 PM Nice that you recovered it and thanks for sharing! |
