Hard Case for 50G, 48GX - Printable Version
+--- Thread: Hard Case for 50G, 48GX (/thread-13723.html)
Hard Case for 50G, 48GX - MattGreer - 09-28-2019 10:56 PM
Looking for a hard case, something more substantial than the included cases, for a 50g and 48gx. Do these exist, or is there one y'all have used that isn't technically for HP but fits?
RE: Hard Case for 50G, 48GX - Dave Frederickson - 09-28-2019 11:14 PM
https://www.ebay.com/i/223088105138
Seller is known for high prices.
These looks more affordable.
https://www.amazon.com/FitSand-Protective-Instruments-SainSmart-Calculator/dp/B014JMH1WO
or
https://www.amazon.com/BOVKE-Calculator-Instruments-Shockproof-Protective/dp/B01HIPOCYE/ref=pd_sbs_229_1/143-2493555-8067640
RE: Hard Case for 50G, 48GX - MattGreer - 09-29-2019 12:26 AM
Yeah, 99 bucks is a bit out of my price range. ?
The one on Amazon that actually has the 50g in it, perfect. Thank you!
RE: Hard Case for 50G, 48GX - JoJo1973 - 09-29-2019 10:21 AM
I've bought this one: it's a bit tight around the sides but has excellent stiffness (it passed a fall test!) and has room for extra batteries, an USB cable and a paperclip.
EC Technology Eva Borsetta... https://www.amazon.it/dp/B01DUDPZ1C?ref=ppx_pop_mob_ap_share
RE: Hard Case for 50G, 48GX - Thott - 09-29-2019 01:21 PM
I have the following hard cases
1. https://www.amazon.de/NiceCool-Instruments-Calculator-Taschenrechner-Schutztasche-Schwarz-Rot/dp/B01L6M2PWG/ref=mp_s_a_1_fkmr0_1?keywords=nicecool+tasche+hp+50g&qid=1569762502&sr=8-1-fkmr0
For the Prime it is to small.....
RE: Hard Case for 50G, 48GX - Thott - 09-29-2019 01:28 PM
........and I have also this hard case
2. https://www.amazon.de/Schutztasche-für-Taschenrechner-Modell-Prime/dp/B07VSH1NFP/ref=mp_s_a_1_1?keywords=case+für+hp+prime+taschenrechner&qid=1569762850&sr=8-1
For the HP41 with card reader both are not high enough.
The price for both are quite reasonable.
The pouch for the connecting cable is not included.
You can fix the calculator at the rear side with a adhesive Velcro strip.
RE: Hard Case for 50G, 48GX - Ken S - 09-29-2019 05:36 PM
(09-28-2019 11:14 PM)Dave Frederickson Wrote:  https://www.ebay.com/i/223088105138
or
The first link is to a soft case which fits over a hard case, but doesn't include the hard case.
Most of the hard cases designed for use with the 48 were meant for surveying use as a data collector. There is also a data collector case for the 50. They tend to be quite bulky and usually expensive when you can find them.
RE: Hard Case for 50G, 48GX - MattGreer - 09-29-2019 08:31 PM
My 48GX is in excellent condition right now as is the case. My biggest issue is that putting that in my backpack, the keys get pressed so sometimes I find the calculator is on when I remove it from the case. Definitely want to protect it.
