Alternative HP-41CL mainframe (OS ROMs) update for beta test - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Alternative HP-41CL mainframe (OS ROMs) update for beta test (/thread-13729.html) |
RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ángel Martin - 10-07-2019 05:05 AM (10-06-2019 08:55 PM)hth Wrote: Regarding this lower and special characters in ED. Because of this, I also added the lowercase patch to [MASK] - so it's all coordinated and that's a much more convenient way to test it. Also it all runs on V41, which shows the lower case on the LCD quite nicely - so no need to print them (which as you say has some quirks)... Using your alternate OS on V41 should be possible, just replace the NUCXT.MOD with your new set of ROMs... I can prepare a new MOD file if you want, but I know you don't use windoze (with good criteria) - so can you emulate it on your system? ÁM RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-07-2019 04:56 PM (10-07-2019 05:05 AM)Ángel Martin Wrote: Because of this, I also added the lowercase patch to [MASK] - so it's all coordinated and that's a much more convenient way to test it. Also it all runs on V41, which shows the lower case on the LCD quite nicely - so no need to print them (which as you say has some quirks)... Yes, but it does not correspond to any actual hardware, so why test it that way, wishful thinking or do I miss something? I can certainly fix my debugger/emulator to support Halfnut characters if needed, and looking at the source indicates that it probably already does. However, I cannot change the ROMs in my Halfnuts, and I do not have any Halfnut LCD on my 41CL (and it is unlikely, if at all possible, that people have such calculators). Maybe it is a matter of different use-cases, my interest is in using real HP-41 hardware. I am open to re-evaluating this, if the situation changes or if I am proven wrong. It is good to know that it has "issues" when printed, as that was what I experienced. Then probably it just works as expected. Finally, about Windows. I do not use it and I did not like it at all in the past. From Windows 8 I think they really got their act together. These days I think it looks cool and I like the user experience. The main issue for me is that I am so used to having Unix at the bottom, that it really cripples me not having it. Having Windows on top of a real Unix (much like Apple did) and I could very well consider using it. However, it costs money, and for me it provides no real value for that money. Speaking of Microsoft, I have just switched from Emacs to VS Code (a Microsoft product) for my HP-41 debugging sessions. Neither is perfect, but VS Code annoys me a lot less these days as a debugger front-end. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Sylvain Cote - 10-07-2019 08:10 PM (10-07-2019 04:56 PM)hth Wrote: Yes, but it does not correspond to any actual hardware, so why test it that way, wishful thinking or do I miss something?I can use my 41CLv2 board and transfer it to a custom build machine if you want (FN-41 with a HN-LCD). (10-07-2019 04:56 PM)hth Wrote: Finally, about Windows. I do not use it and I did not like it at all in the past. From Windows 8 I think they really got their act together.I used Windows a lot professionally and personally until I got tired of spending more time managing the platform than using it. Since then, 2005, I refused all jobs that was forcing me to use Windows, converted all existing home machines to Linux/BSD and when buying new machines, it was either Linux/BSD-on-PC or macOS-on-MacBookPro. On rare times that I have no choice to use Windows in a VM, I always uses Windows 7, I just cannot stand the UI craziness of Windows 8.X and Windows 10, strange how perception works ![]() Sylvain RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-07-2019 09:13 PM (10-07-2019 08:10 PM)Sylvain Cote Wrote: I can use my 41CLv2 board and transfer it to a custom build machine if you want (FN-41 with a HN-LCD). So it is possible to do that. Hmm, then I should probably sense if it the hardware has a Halfnut display and apply the lower-case display patch for such machines. Quote:On rare times that I have no choice to use Windows in a VM, I always uses Windows 7, I just cannot stand the UI craziness of Windows 8.X and Windows 10, strange how perception works Yes, I know that my perception of Windows is totally the opposite of most Windows users. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Sylvain Cote - 10-08-2019 03:35 AM (10-07-2019 09:13 PM)hth Wrote:Well, I never tried it but I can surely try!(10-07-2019 08:10 PM)Sylvain Cote Wrote: I can use my 41CLv2 board and transfer it to a custom build machine if you want (FN-41 with a HN-LCD).So it is possible to do that. Hmm, then I should probably sense if it the hardware has a Halfnut display and apply the lower-case display patch for such machines. I will not be able to have enough free time for this test until next weekend, I will update this thread after my franken-nut has been created. Sylvain RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ángel Martin - 10-08-2019 05:44 AM (10-07-2019 04:56 PM)hth Wrote:(10-07-2019 05:05 AM)Ángel Martin Wrote: Because of this, I also added the lowercase patch to [MASK] - so it's all coordinated and that's a much more convenient way to test it. Also it all runs on V41, which shows the lower case on the LCD quite nicely - so no need to print them (which as you say has some quirks)... Well, testing on V41with patched [MASK] confirms that the [ED] patch is correct. That has a ton of value in my mind. And who knows, there may be other/new machines cappable of displaying the lower case chars soon available... time will tell. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ángel Martin - 10-08-2019 05:47 AM (10-07-2019 08:10 PM)Sylvain Cote Wrote: On rare times that I have no choice to use Windows in a VM, I always uses Windows 7, I just cannot stand the UI craziness of Windows 8.X and Windows 10, strange how perception works Same here. If windoze was bad before they really lost their marbles with the craziness of Win-8 and Win-10, sorry to say that for me (IMHO) they are complete trash... - maybe I'm just too old to start linking the touch-screen like U/I's and all the other "fancy" stuff, but all that constant, piece-meal updating every other day on W-10 is insufferable! RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-08-2019 06:08 AM Turns out that it was not so easy to sense the Halfnut and fix the lower case characters. The code itself is some 30 words, but there is no room for it other than in bank 5.2, and that will not work. It is a bit hard to explain, but I ran into this before. The problem is that a pushed return address is just an address, there are no bank bits being pushed. If the called routine fiddles with the bank bits (to call the 30-word slice in bank 2), it loses track of which bank it was originally called from. The result is that it may return to the wrong bank. There are four alternatives as I see it. 1. Restructure code to make room somewhere else for it (in practise it means page 3). 2. Make two different builds, one with and one without the fix the MASK for lower case characters. 3. Assume there is a halfnut display, even though only franken-nut and emulators can make use of it, no ordinary 41CL can. 4. Forget it, at least for now. I do not want to do (3) at least. I rather keep the star-burst character behavior we are used to when not using Halfnuts. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ángel Martin - 10-08-2019 08:51 AM Sorry but I'm not sure I follow you - are these options for the [MASK] patch? If so, it simply replaces the current code (no need for additional room), and it works for both full-nuts and half-nuts. Therefore I see no need for two different builds. I'd leave the starburst chars alone in Full-nuts, that's a hardware limitation. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-08-2019 06:20 PM (10-08-2019 08:51 AM)Ángel Martin Wrote: Sorry but I'm not sure I follow you - are these options for the [MASK] patch? I am under the impression that it is the MASK routine that introduces the starburst characters when there is no suitable alternative: Code:
I tried to change it as suggested on my 41CL, but it does work so well. The existing lower case characters (a-e) stop working in alpha register and all lower case characters are replaced by a space. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-11-2019 01:43 AM To anyone that are beta testing, here is a link to an XFUNS5 image that contains a patch for entering lower-case and special characters in ED: https://drive.google.com/open?id=1oqVfFLgtVdsriCjwrAsH1fwfavjaqfBy Checksum: ff4c5c2a (Lower-case characters apart from a-e are still displayed as boxed stars) RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ken S - 10-19-2019 01:53 AM How is the beta test going? I have an hp41 coming in a few weeks which will be converted to a CL and am interested in trying this. I plan on setting this one up for surveying calculations (and GPS when Monte gets that module sorted). I love the idea of so much extended memory to store points in. I will have to check if the software which stores to Xmemory is compatible with this but am sure I can make one of the programs work with this. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-22-2019 01:41 AM (10-19-2019 01:53 AM)Ken S Wrote: How is the beta test going? I have an hp41 coming in a few weeks which will be converted to a CL and am interested in trying this. I plan on setting this one up for surveying calculations (and GPS when Monte gets that module sorted). I love the idea of so much extended memory to store points in. I will have to check if the software which stores to Xmemory is compatible with this but am sure I can make one of the programs work with this. I have not heard so much. I think it is known by now that it will not work with CCD and modules that borrow code from it for accessing extended memory. I have also seen some issues with running from RAM, which is why I flashed it as soon as I trusted it. Meaning, when my automated tests worked and I could use the calculator normally with no noticeable issues. I have not done any particular X-memory tests recently, but I do use the beta ROMs. It is mostly for testing other coming modules (doing normal things and playing with other half broken code). In any case, it sounds like you could be a good beta tester of it? RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ken S - 10-22-2019 02:53 AM Sounds good, once I get the donor calculator in and build the 41CL I will give it a try. Any idea if this will work on the upcoming DM41X? RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 10-22-2019 07:15 AM (10-22-2019 02:53 AM)Ken S Wrote: Sounds good, once I get the donor calculator in and build the 41CL I will give it a try. Any idea if this will work on the upcoming DM41X? Let me know when you are ready. I have no idea if it will work on the DM41X. It depends on whether it has RAM in the address range 400-EFF (the upper page limit is configurable at build time), and without the gaps that exist in RAM page 2 and 3. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Ken S - 10-25-2019 11:50 PM (10-22-2019 07:15 AM)hth Wrote:(10-22-2019 02:53 AM)Ken S Wrote: Sounds good, once I get the donor calculator in and build the 41CL I will give it a try. Any idea if this will work on the upcoming DM41X? Pm sent RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 12-24-2019 06:05 AM Long time and no update to this. I just found a very minor problem with corrected XROM XKD mechanism that will warrant a correction. I also fixed the "FOO IND L" bug where FOO is an XROM, as mentioned here https://www.hpmuseum.org/forum/thread-13935-post-123124.html#pid123124 which means two issues. Anyone has comments on the larger extended memory? RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Monte Dalrymple - 12-27-2019 02:04 AM (12-24-2019 06:05 AM)hth Wrote: Long time and no update to this. I just found a very minor problem with corrected XROM XKD mechanism that will warrant a correction. Do I have this yet? I'm getting ready to do a monthly update. RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - Sylvain Cote - 12-27-2019 01:12 PM (12-24-2019 06:05 AM)hth Wrote: Anyone has comments on the larger extended memory?Finally some free time to test this. Test machine is a 41CLv2 and I have not updated to the latest OS ROMs yet. AUTOSTART module is mapped and the following program is executed at each power on Code: LBL "RECOVER" I have successfully executed the following program that creates a data file using all extended memory available, then sequentially write and read from that file. Program logic: Code: A: Initialisation Program listing: Code: 01◆LBL "TSEM" // Test Super-Extended Memory Note 2: turbo 50 was set before running the program. Program output: Code: WRITING Messages: Code: SUCCESS // all tests were successfully passed CAT 4 Code: TSEM D3403 RE: Alternative HP-41CL mainframe (OS ROMs) update for beta test - hth - 12-28-2019 01:44 AM (12-27-2019 02:04 AM)Monte Dalrymple Wrote:(12-24-2019 06:05 AM)hth Wrote: Long time and no update to this. I just found a very minor problem with corrected XROM XKD mechanism that will warrant a correction. I need to update it and make new images, fixing the two issues I have already. I think you can include it in some future update, but not this one. |
