HP reduces drastically employees - Printable Version
+--- Thread: HP reduces drastically employees (/thread-13756.html)
Pages: 1 2 3
RE: HP reduces drastically employees - burkhard - 10-14-2019 03:41 PM
(10-10-2019 08:16 PM)Hlib Wrote:  I paid real money for hp-50g(1), hp-50h(2), hp-48gii(256K), hp-39gs.
I recognize the others, but what's an hp-50h ?
RE: HP reduces drastically employees - Wes Loewer - 10-14-2019 04:31 PM
(10-14-2019 02:07 PM)KeithB Wrote:
(10-10-2019 08:35 PM)KeithB Wrote:  ... since I can't use the Prime for security reasons.
I work at a national lab in Albuquerque working on secret stuff for the DOE
I had narrowed it down to something like that, or else maybe "security reasons" meant you were afraid of your Prime getting stolen at work. :-)
RE: HP reduces drastically employees - Valentin Albillo - 10-14-2019 04:32 PM
(10-14-2019 02:07 PM)KeithB Wrote:  I am probably bending the rules a bit with the HP71B, but you cannot smuggle many secrets in 48K RAM!
[Image: HP%20Picture%20VA713%20-%20HP-71B%20-%20DSC02391.jpg]
That much RAM can hold 40-50 pages full of uncompressed text and the HP-71B can have as much as 3 times more RAM plugged in. Add a little compression and there you are, 200-300 pages are within reach.
V.
RE: HP reduces drastically employees - KeithB - 10-14-2019 04:40 PM
Shhhh! What are you trying to do, get my HP71 taken away? I meant *my* HP71B only had 48K of RAM.
RE: HP reduces drastically employees - Valentin Albillo - 10-14-2019 04:47 PM
(10-14-2019 04:40 PM)KeithB Wrote:  Shhhh! What are you trying to do, get my HP71 taken away? I meant *my* HP71B only had 48K of RAM.
I perfectly understood what you meant. I was merely pointing out that nothing prevents you or someone else fitting an HP-71B with RAM enough to hold 200-300 pages of text or more and you can "smuggle many secrets" in that many pages.
V.
RE: HP reduces drastically employees - Eddie W. Shore - 10-14-2019 07:22 PM
(10-04-2019 03:11 PM)David Hayden Wrote:
(10-04-2019 02:40 PM)Claudio L. Wrote:  My suggestion: Modify the firmware of the HP Prime to require a genuine HP ink cartridge
How much ink is required to update the display on an HP Prime? If I switch to a white background, will that reduce the amount? Is color more expensive than B/W? Is there a B/W theme that I should use instead?
Wink
Dave
Will new calculation slots be shipped on a monthly basis? Any roll over privileges? ?
