Missing segments on HP-65 - Printable Version
+--- Thread: Missing segments on HP-65 (/thread-14147.html)
Missing segments on HP-65 - Moggul - 12-10-2019 09:29 PM
I just acquired an HP-65 which was advertised as non working. It came in a beautiful case with the Standard and Math 1 pacs so I thought to give it a try.
Turns out the previous owner tried to power it up directly from the charger with no suggess, but when I installed a good power pack it instantly came to life.
The problem is some of the LED segments do not light up. As you can see in the pictures digits 3, 5 and 8 do not light up properly (the display should read -8888888888.-88).
Is there a known cure for this? Should I open it up and clean the contacts? Or is it a lost cause?
Thanks!!!
RE: Missing segments on HP-65 - grsbanks - 12-10-2019 09:49 PM
A Classic should run on the charger alone. If yours doesn't then there's probably a fault in the power supply within the calculator or even with the charger.
Re the LED, I think it's the LED display itself that's faulty. A fault in the anode driver would result in the same segment(s) missing from every digit and a fault in the cathode driver would mean entire digits not working. At least I think this is the case. Someone who knows more about the electronics will no doubt be able to put me right if I'm wrong (Tony? Bernhard?)
RE: Missing segments on HP-65 - teenix - 12-11-2019 12:22 AM
It looks like those LED segments have failed either fully or partially. I have seen segments fail like this before and it looks like the only way to fix it is to try to find replacements for the 5 digit LED modules (any classic types will do) or another key/display board.
cheers
Tony
(12-10-2019 09:29 PM)Moggul Wrote:  I just acquired an HP-65 which was advertised as non working. It came in a beautiful case with the Standard and Math 1 pacs so I thought to give it a try.
Thanks!!!
RE: Missing segments on HP-65 - PANAMATIK - 12-11-2019 07:26 AM
(12-11-2019 12:22 AM)teenix Wrote:  --- the only way to fix it is to try to find replacements for the 5 digit LED modules (any classic types will do) ....
Search for QDSP6061 bubble display. Relatively easy to find.
Edit: But I'm not sure if this is the type with the decimal dot inside the number.
Bernhard
RE: Missing segments on HP-65 - Moggul - 12-11-2019 04:46 PM
Bernhard
Thanks Bernhard.
I found these on ebay:
https://www.ebay.es/itm/Vintage-bubble-HP-LED-display-5-digits-decimal-point-ouside-digit-HP-QDSP-6061/174008862430?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D201609081​05057%26meid%3D722f603f43b6421da18bd33f378c5503%26pid%3D100675%26rk%3D5%26rkt%3D​15%26sd%3D174122379850%26itm%3D174008862430%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A37065eee-1c35-11ea-913b-74dbd1802eea%7Cparentrq%3Af5d7211716e0a4b77cdd1d1dffc3c6b9%7Ciid%3A1
However I believe they are the wrong type: "Vintage 7 segment LED display, 5 DIGITS, decimal dot outside the digit." I am looking for "decimal dot inside the digit", right?
(12-10-2019 09:49 PM)grsbanks Wrote:  A Classic should run on the charger alone. If yours doesn't then there's probably a fault in the power supply within the calculator or even with the charger.
I checked and the calculator runs when connected to the charger alone, so at least that part is good Smile
RE: Missing segments on HP-65 - teenix - 12-11-2019 06:05 PM
(12-11-2019 04:46 PM)Moggul Wrote:  However I believe they are the wrong type: "Vintage 7 segment LED display, 5 DIGITS, decimal dot outside the digit." I am looking for "decimal dot inside the digit", right?
Yes, in the middle of the CDEG segments.
cheers
Tony
RE: Missing segments on HP-65 - Moggul - 12-11-2019 06:14 PM
cheers
Tony
These, right?
https://www.ebay.es/itm/VINTAGE-ORIGINAL-HP-5-DIGIT-BUBBLE-RED-LED-RETRO-DISPLAY-5082-7405-fbb15a25-/401372399431
