Were batteries preinstalled in 32s 50th Anniversary? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Were batteries preinstalled in 32s 50th Anniversary? (/thread-14243.html) |
Were batteries preinstalled in 32s 50th Anniversary? - David Hayden - 12-27-2019 03:15 PM I've acquired a new 32s 50th anniversary limited edition. One thing really worries me: from what I read in the 32s manual, they came with alkaline batteries. Does that mean I have 30 years of battery acid inside the calculator? Is it ruined? By the way, there's an excellent chance that I'll donate this as a prize at HHC 2020. RE: Were batteries preinstalled in 32s 50th Anniversary? - BruceH - 12-27-2019 11:01 PM The calc or the vintage battery acid? ;-) RE: Were batteries preinstalled in 32s 50th Anniversary? - Jeff O. - 12-30-2019 05:50 PM (12-27-2019 03:15 PM)David Hayden Wrote: I've acquired a new 32s 50th anniversary limited edition. One thing really worries me: from what I read in the 32s manual, they came with alkaline batteries. Does that mean I have 30 years of battery acid inside the calculator? Is it ruined? David, can you open it and look, or is it still in transit to you? I do not recall ever seeing an LR44/A76 button cell leak, so perhaps they were not as prone to do so as the larger cells are. Hopefully they will just be dead. Sounds like a good door prize for a lucky HHC 2020 attendee. RE: Were batteries preinstalled in 32s 50th Anniversary? - Massimo Gnerucci - 12-30-2019 06:28 PM I had to carefully cut the plastic film protecting a NIB 27S, just to slip out the calculator and remove the batteries. RE: Were batteries preinstalled in 32s 50th Anniversary? - ijabbott - 12-30-2019 06:36 PM (12-30-2019 05:50 PM)Jeff O. Wrote: David, can you open it and look, or is it still in transit to you? I do not recall ever seeing an LR44/A76 button cell leak, so perhaps they were not as prone to do so as the larger cells are. Hopefully they will just be dead. Sounds like a good door prize for a lucky HHC 2020 attendee. I think the alkaline LR44 button cells are prone to leak the same as AAA and AA alkaline cells, and I've seen a few worse for wear alkaline button cells before. I've yet to see a silver oxide SR44 or SR44W or equivalent 303/357 leak. RE: Were batteries preinstalled in 32s 50th Anniversary? - Jeff O. - 12-30-2019 09:05 PM (12-30-2019 06:36 PM)ijabbott Wrote: I think the alkaline LR44 button cells are prone to leak the same as AAA and AA alkaline cells, and I've seen a few worse for wear alkaline button cells before. I've yet to see a silver oxide SR44 or SR44W or equivalent 303/357 leak. Probably the silver oxides I've never seen leak. RE: Were batteries preinstalled in 32s 50th Anniversary? - Gerald H - 12-31-2019 05:27 AM (12-30-2019 06:36 PM)ijabbott Wrote: I think the alkaline LR44 button cells are prone to leak the same as AAA and AA alkaline cells, and I've seen a few worse for wear alkaline button cells before. I've yet to see a silver oxide SR44 or SR44W or equivalent 303/357 leak. Same experience for me. RE: Were batteries preinstalled in 32s 50th Anniversary? - David Hayden - 12-31-2019 09:25 PM Update: I carefully removed the calculator from the package and checked the battery compartment. LR-44 batteries were installed by pressing the ON button did nothing. I swapped with the batteries in my 32sii and the it still didn't turn on. The batteries in the 32s worked fine in my 32sii I tried ON and + to adjust contrast. No luck. So I hunted for instructions on how to reset it, found them, and upon a reset, the 32s came up with this existing batteries. Yay! I put everything back together in the package, ready for HHC2020 Thanks for the comments and suggestions. Dave |
