HP 65 with two identical glod keys (f-1) - Printable Version
+--- Thread: HP 65 with two identical glod keys (f-1) (/thread-14244.html)
HP 65 with two identical glod keys (f-1) - Alevin - 12-27-2019 07:41 PM
Hi
I have just realized that my hp-65 has the same label in both gold shift keys. They work properly but instead of f and f-1 gold keys , the labels print are f-1 in both.
There is NO trace of being opened, the back label is pristine. Indeed all the calculator is pristine, it seems not being used ever. SN 1509A 02191
Hypotesis:
A home made repair substituing a broken f key for a f-1 found somewhere else, but it would have deteriorated the back label.
A factory repair would have remove the back label and substitued it with a new one, but.... are the factory technicians so blunger to miss the f key with a f-1?
Or just is a rare factory mistake on production line not detected by quality control? (or a defective item that was not comercialized nor destroyed but kept by some HP worker as a unique item)
Does anybody know about some similar bizarre singular mistake?
Best regards
RE: HP 65 with two identical glod keys (f-1) - Massimo Gnerucci - 12-27-2019 08:02 PM
My money is on a factory mistake on production line.
RE: HP 65 with two identical glod keys (f-1) - Alevin - 12-27-2019 08:33 PM
Here they come, a couple of pics
Front
Rear
I see that the trade mark front label
"Helwett Packard 65"
is a little detached and slightly deformed in one side.
Removing this label is requiered to dissasembling the calculator?
RE: HP 65 with two identical glod keys (f-1) - teenix - 12-27-2019 08:59 PM
(12-27-2019 08:33 PM)Alevin Wrote:  Removing this label is requiered to dissasembling the calculator?
Not this one. The label underneath the calculator has 2 screws hiding under it.
cheers
Tony
