HP15C LE firmware - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP15C LE firmware (/thread-14328.html) |
HP15C LE firmware - BarryGKnapp - 01-07-2020 09:38 PM My HP15c Limited Edition is number 05320. It has the "running" display bug, and the failure to pause (PSE) bug when running a program. Do later editions of the 15C Limited Edition have these bugs fixed? If so, beginning with which serial number? (I presume that there is no way to obtain a firmware update, right?) RE: HP15C LE firmware - Namir - 01-07-2020 09:46 PM (01-07-2020 09:38 PM)BarryGKnapp Wrote: My HP15c Limited Edition is number 05320. It has the "running" display bug, and the failure to pause (PSE) bug when running a program. Do later editions of the 15C Limited Edition have these bugs fixed? If so, beginning with which serial number? (I presume that there is no way to obtain a firmware update, right?) Sorry friend, the PAUSE bug has never been fixed! Not sure any other bug has been fixed. :-( |
