Ilper - side by side configuration error - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: Ilper - side by side configuration error (/thread-14333.html) |
Ilper - side by side configuration error - Harald - 01-08-2020 01:35 PM I have a new laptop (Windows 10) at work and I can't get Ilper (V2.3) to run anymore. I get a side-by-side configuration error. Does Ilper require any DLLs that might not be present anymore? Has anyone had the same issue? Cheers, Harald RE: Ilper - side by side configuration error - rprosperi - 01-08-2020 01:54 PM Try installing the VS2005 run-time pkg, available at the bottom of Christoph's website, here: https://hp.giesselink.com/hpil.htm RE: Ilper - side by side configuration error - grsbanks - 01-08-2020 01:55 PM You need to install the VS2005 runtime library. It's available here: https://hp.giesselink.com/Runtime/vcredist2005_x86.exe RE: Ilper - side by side configuration error - Harald - 01-08-2020 03:49 PM Thank you to both of you! That did the trick. It seems I had a newer version installed which did not work... |
