New G2 Firmware 20200116 - Problems - FIXED w/ 20200121 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: New G2 Firmware 20200116 - Problems - FIXED w/ 20200121 (/thread-14373.html) |
RE: New G2 Firmware 20200116 - Problems - smp - 01-22-2020 09:35 PM I just installed the 2020 01 21 Firmware from my Mac: Software Version: 2.1.14433 (2020 01 21) Hardware Version: D CAS Version: 1.5.0 Serial Number: 9CJ8... Operating System: V2.060.650 Thanks very much to all the folks who provided assistance and advice here, and also to all the folks at HP who quickly fixed this firmware after the issue was reported. smp RE: New G2 Firmware 20200116 - Problems - AstroJerry - 01-22-2020 10:54 PM My G2 now works! Thanks to everyone! RE: New G2 Firmware 20200116 - Problems - Tim Wessman - 01-23-2020 04:53 AM Hello, Thank you for everyone that helped check this. I've resumed the process of officially releasing the files out... now on to bigger and (hopefully) better things since this minor maintenance release is out the door. RE: New G2 Firmware 20200116 - Problems - EricV - 01-23-2020 04:55 AM Updated G2 to 20200121, seems to be working just fine now, Thanks for the quick fix. RE: New G2 Firmware 20200116 - Problems - cyrille de brébisson - 01-23-2020 06:12 AM Thanks to all of you who helped find and correct the touch driver issue! Cyrille RE: New G2 Firmware 20200116 - Problems - Carlos295pz - 01-23-2020 07:58 AM I found some problems, but not of the latest version, they are mostly things that are dragged from past versions, I will take the time to document it, the day I was going to report it they launched the 2020 01 16 and it took me away. RE: New G2 Firmware 20200116 - Problems - Dirk.nl - 01-23-2020 09:15 AM Hooray, touchscreen works on my G2 again. Note: On hpcalc.org the G2 firmware still shows the old update code of 20200116, select it and download the new 20200121 zip file. HP Prime team; thank you !! RE: New G2 Firmware 20200116 - Problems - medwatt - 01-23-2020 01:02 PM The 2020 01 21 firmware has solved the touch screen issue on my G2. I don't know if this is the place to mention it, but the issue which I reported several times still hasn't been solved. If I install the control systems app and the calculator reboots, it crashes and clears the entire memory. This means the only way I can use this app is to never turn the calculator completely off or hope nothing crashes the calculator, forcing a reboot. RE: New G2 Firmware 20200116 - Problems - Cristóbal De Jesús - 01-23-2020 02:54 PM 14433... … … Where's the file? RE: New G2 Firmware 20200116 - Problems - Dirk.nl - 01-23-2020 03:48 PM Hello Christóbal, Go to hpcalc.org. At the bottom (almost) it says "Updated HP Prime G2 Firmware to 2.1.14425 (2020-01-16) on PC". Select this and you will see https://www.hpcalc.org/prime/pc/HP_Prime_Calculator_G2_Firmware_20200121.zip Download this and unzip this. How to proceed is given several times in the forum. RE: New G2 Firmware 20200116 - Problems - Cristóbal De Jesús - 01-23-2020 05:17 PM (01-23-2020 03:48 PM)Dirk.nl Wrote: Hello Christóbal, Thanks, quite touchy now... RE: New G2 Firmware 20200116 - Problems - Dirk.nl - 01-23-2020 05:24 PM Okay, Christóbal ! RE: New G2 Firmware 20200116 - Problems - jp91620 - 01-23-2020 06:04 PM Great !!! Thanks a lot jp RE: New G2 Firmware 20200116 - Problems - Eddie W. Shore - 01-24-2020 03:14 AM (01-22-2020 03:07 AM)Mark Hardman Wrote:(01-22-2020 02:55 AM)Eddie W. Shore Wrote: Doing the On + symb just flashes the screen for me - no numbers. Not sure if I'm doing it right. But I now notice a short "load" time of the screen when I turn on the Prime. I have 3 2 Thanks. RE: New G2 Firmware 20200116 - Problems - rombva - 01-24-2020 12:13 PM There is an additional issue on G2 besides a touch screen work problem. It still remains after the last update. After installing the 20200121 FW my Prime G2 demonstrates a strange behavior after soft rebooting [ON]&[Symb]. 1) Turn power off and than turn power on. 2) After the first reboot on the Prime's screen continuosly the HP logo appears. 3) After the second reboot all the Prime's memory seems to be lost, nothing appears in the mem manager. 4) After the third reboot all progrms restore in the Prime's memory (all notes are loosing). Repeated rebooting shows the same sequence 1) - 4). P.S. After installing new FW all data remain on calc. RE: New G2 Firmware 20200116 - Problems - grsbanks - 01-24-2020 12:19 PM (01-24-2020 12:13 PM)rombva Wrote: After installing the 20200121 FW my Prime G2 demonstrates a strange behavior after soft rebooting [ON]&[Symb]. Not here. Just tried this on my G2 and it works as expected. RE: New G2 Firmware 20200116 - Problems - rombva - 01-24-2020 01:40 PM (01-24-2020 12:19 PM)grsbanks Wrote:(01-24-2020 12:13 PM)rombva Wrote: After installing the 20200121 FW my Prime G2 demonstrates a strange behavior after soft rebooting [ON]&[Symb]. I'm happy for your sake. But I have this problem with my G2. RE: New G2 Firmware 20200116 - Problems - grsbanks - 01-24-2020 01:57 PM (01-24-2020 01:40 PM)rombva Wrote: I'm happy for your sake. But I have this problem with my G2. Precisely. It's not with the firmware (if it was, my Prime would exhibit the same behaviour, as would everyone else's), it's with your Prime. The only thing you can do is reformat the C: drive and try your test again. If it still misbehaves then your Prime is faulty. If not, then keep adding your programs one by one and repeating the test until the Prime fails again. When it does fail, it's the program that you added last that is most likely the cause of the problem. RE: New G2 Firmware 20200116 - Problems - TheLastMillennial - 01-24-2020 04:48 PM Hey my G2's touch screen still doesn't work on the latest 2.1.14425 (2020 01 20)! When I go to the update mode, I have 3 3 in the top left. My recovery screen info is: data Version: V14424 OS Version: 2.1 PCB Version: D Touch IC FW Ver: ilitek-00 EDIT: Rolling back to 20191120 fixes the display and changes the Touch IC FW Ver to GT5688-516 RE: New G2 Firmware 20200116 - Problems - Voldemar - 01-24-2020 05:08 PM (01-24-2020 04:48 PM)TheLastMillennial Wrote: 2020 01 20You need 20200121. |
