49G 50G STAT3.8e.hp: Multiple linear regression & Restricted model - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: 49G 50G STAT3.8e.hp: Multiple linear regression & Restricted model (/thread-14376.html) |
49G 50G STAT3.8e.hp: Multiple linear regression & Restricted model - Gil - 01-17-2020 02:25 PM I just integrated now, automatically, in the matrix of the results : - the VIFs (Variance Inflation Factors) & - the CONDITION[/i] Indexes As always, just copy the full Directory (without the .DOC ending) in your phone appli EMU48 and enjoy your statistical analysis. Gil Version 3.8 fixes the Var coeff: - Mean of Y calculated beforehand; - Var coeff set as infinity when mean of Y = 0. & explains better the use of 5 CF/SF in Version 3.8e. RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - SammysHP - 01-17-2020 09:53 PM Thank you for your work! It might be easier to collect all posts of this tool in a single thread. Maybe a mod can merge the threads. RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - Gil - 01-17-2020 10:05 PM I agree, you are right. I was not sure what was better: new thread for new version or old thread + reply with inclusion of new version of the former (old) program; apparently, the second option seems preferable. Regards. Gil RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - rprosperi - 01-18-2020 02:48 AM (01-17-2020 10:05 PM)Gil Wrote: I agree, you are right. What seems to work best here is to extend the old thread, but also update your initial post (top of 1st page) with the latest version of the file, and any related notes about usage, changed specs., etc. This minimizes the number of threads on the same topic, makes it easier for folks trying to find the thread on your topic, and by always updating the initial post, readers know where to find the latest files & notes without searching through the full thread. RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - Gil - 01-18-2020 03:21 AM Just for your information : The programs themselves are to be found in STAT/REG. The documentation or notes are to be found in STAT/NOTES. Exact Input-Argument form for each of the 5 main programs fully explained, each time, at the beginning of the respective program (in form of a long string). RE: HP49-50G : STAT3.4.DOC, Version 3.4 of linear regression - Gil - 01-19-2020 05:57 PM 3.4 19.1.2020 Changed warning message-levels for colinearity: VIF10 CONDIT.IND15&30 In last line of RESUL of C.REG & C.RESTR?: [Screens 1.4&2.5] unit ¦%¦ added to VARIAT.COEF RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - rprosperi - 01-19-2020 08:34 PM (01-18-2020 02:48 AM)rprosperi Wrote: What seems to work best here is to extend the old thread, but also update your initial post (top of 1st page) with the latest version of the file, and any related notes about usage, changed specs., etc. However, feel free to ignore that advice... RE: HP49-50G : STAT3.3.DOC, Version 3.3 of linear regression - Gil - 03-02-2020 08:57 AM Just changed way of calculating VIF (Variance Inflation Factors) when multiple linear regression model is without intercept (same results now as with SAS or R statistical programs). Besides that, the structure remains the same : probabilities, t, beta, covariances, (¹/²) (partial) correlations, test on beta's and on alternative model suppressing independent X variables, (adjusted) R2, multicolinearity (condition number), anova, Spearman’s coefficient and critical values, etc. Explanations and examples still in the downloaded file and to be read only with the calculator as they were programs by themselves. Commentaries welcome. Regards, Gil RE: (49G 50G): STAT3.8e.DOC, Versions d/e of linear regression - Gil - 04-16-2022 02:15 PM New version 3.7 with a possible error in the variable name R2mod and its location. Version 3.8 fixes the Var coeff: - Mean of Y calculated beforehand; - Var coeff set as infinity when mean of Y = 0. Regards, Gil Campart RE: 49G 50G STAT3.8e.DOC: Multiple linear regression & Restricted model - Gil - 01-12-2023 01:31 PM Version with .hp ending (instead of the previous, confusing. DOC ending). |
