HP 17Bii+ emulator availability? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 17Bii+ emulator availability? (/thread-14465.html) Pages: 1 2 |
RE: HP 17Bii+ emulator availability? - rprosperi - 02-06-2020 01:49 PM (02-05-2020 11:26 PM)mfleming Wrote: Harrah! Thanks Dave! Everything old is new again, and here's my proof... Mark - Isn't that device based on Android? Does it run DOSBox ? BTW, Great old meets new photo!! Another might be this machine running the CK actually connected to an HP Palmtop; it may appear that the machines were trying to mate somehow... RE: HP 17Bii+ emulator availability? - mfleming - 02-06-2020 04:15 PM (02-06-2020 01:49 PM)rprosperi Wrote: Mark - Isn't that device based on Android? Does it run DOSBox ? As Dave pointed out, the device is from Planet Computer in the U.K., though it is their new PDA/Phone model. https://www.www3.planetcom.co.uk/cosmo-communicator It runs Android 9, but they promise soon to release a Linux port so you can dual-boot like the Gemini PDA. I'm running DOSBox from Play Store but having some problem with keyboard mapping at the moment. With fewer keys than a standard keyboard, it uses a function key to map many of the lesser used punctuation characters, and DOSBox doesn't grok them. Hopefully get that ironed out soon so a side-by-side can be posted! ~Mark RE: HP 17Bii+ emulator availability? - rprosperi - 02-06-2020 11:31 PM (02-06-2020 04:15 PM)mfleming Wrote: As Dave pointed out, the device is from Planet Computer in the U.K., though it is their new PDA/Phone model. I am familiar with the device and followed it's protracted birth over many years, and I thought there Android and Win10 versions, had not heard about a Linux version coming, that should be interesting. I also didn't know you could run DOSBox on it, that makes it more interesting. Now if only I can find my original exotic CONFIG.SYS and AUTOEXECT.BAT files to configure QEMM, PC-Kwik Cache, Fansi-Console and 4DOS shell. Those were the DOS days... RE: HP 17Bii+ emulator availability? - Massimo Gnerucci - 02-07-2020 06:57 AM (02-06-2020 11:31 PM)rprosperi Wrote: Now if only I can find my original exotic CONFIG.SYS and AUTOEXECT.BAT files to configure QEMM, PC-Kwik Cache, Fansi-Console and 4DOS shell. Those were the DOS days... Still have them: on a VM from a 1996 backup... :D Also have another one with QEMM + DesQview! Fun, fun, fun!! RE: HP 17Bii+ emulator availability? - jthole - 02-07-2020 10:38 AM (02-05-2020 12:00 AM)rprosperi Wrote: JT - Since you are aware of the 17BII+ Solver bugs, and are testing these things, maybe run some of the 'bad cases' on both the real device and emulator and see if the results are identical; that may answer this. I have to trust others for the results on the real device (I only have the older 17Bii, and not the "Plus" - which actually should be called the "Minus" ...), but I tested the emulator against the known flaws (e.g. this equation: A=0xsigma(I:1:10:1:L(S:S+I)) ). Interestingly, the emulator seems more flawed here than the actual "Plus" (which is reported to return 110 for S): On the older 17Bii, I get A=0 and S=55 (correct evaluation of the expression). On the "Plus", people got A=0 and S=110. On the emulator, I get "SOLUTION NOT FOUND", which obviously is not correct. That is, after clearing the variables, and also after explicitly assigning 0 to them. So, with the remark that I cannot test it on a real "Plus", the emulator seems to have a serious flaw here indeed. |
