hp41cx utility function to trim an ASCII EM file - Printable Version
+--- Thread: hp41cx utility function to trim an ASCII EM file (/thread-14467.html)
hp41cx utility function to trim an ASCII EM file - twdeckard - 02-04-2020 01:05 AM
Can anyone help me recall a small utility function that automatically resized an EM flle to the minimum size for its current number of records?
I thought it was in the original forum?
Thanks!
Todd
RE: hp41cx utility function to trim an ASCII EM file - Lyle Lower - 02-04-2020 03:04 AM
I believe this post may be what you are looking for?
https://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv013.cgi?read=38991
Cheers,
Lyle
RE: hp41cx utility function to trim an ASCII EM file - dayd - 02-04-2020 03:57 AM
You may have to adapt to fit your needs but here’s one:
https://www.hpmuseum.org/forum/thread-6552-post-60476.html#pid60476
André
RE: hp41cx utility function to trim an ASCII EM file - Ángel Martin - 02-04-2020 06:03 AM
(02-04-2020 01:05 AM)twdeckard Wrote:  Can anyone help me recall a small utility function that automatically resized an EM flle to the minimum size for its current number of records?
Define "minimum number of records": all non-zero, consecutive, at the END of the file; is that it?
So the routine4 will have to start checking from the last record, counting records until finding the first non-zero value. There can be more zero records in-between that one found and the file head, but those should remain, correct?
RE: hp41cx utility function to trim an ASCII EM file - twdeckard - 02-04-2020 12:58 PM
(02-04-2020 03:57 AM)dayd Wrote:  You may have to adapt to fit your needs but here’s one:
André
perfect! that was it
RE: hp41cx utility function to trim an ASCII EM file - dayd - 02-05-2020 01:50 AM
(02-04-2020 12:58 PM)twdeckard Wrote:  perfect! that was it
Well... not so perfect it seems, I found a mistake and made a little correction;
=> PKFLAS
