AMC-OSX Question - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: AMC-OSX Question (/thread-14527.html) |
AMC-OSX Question - Sylvain Cote - 02-18-2020 04:17 AM Hello Ángel & Monte, There is a file (AMCOSX4.ROM) in the last version of the rom files (rom_files_200130.zip) that is not listed in any of the memory reference files (mem_ref_v5.txt, mem_ref_v2.txt & mem_ref.txt). If this a version of AMC-OSX (AMC-OSX.ROM) using library 4 (LIBRARY4.ROM) ? Sylvain EDIT: I just checked and I it seems that it had been there forever (since 2012) but I never took notice. RE: AMC-OSX Question - Monte Dalrymple - 02-18-2020 05:04 AM It's probably an early version, where I didn't scrub it from the directory after a name change. RE: AMC-OSX Question - Ángel Martin - 02-18-2020 07:21 AM (02-18-2020 04:17 AM)Sylvain Cote Wrote: There is a file (AMCOSX4.ROM) in the last version of the rom files (rom_files_200130.zip) that is not listed in any of the memory reference files (mem_ref_v5.txt, mem_ref_v2.txt & mem_ref.txt). I guess you refer to the "AOSX" ROM image located at 0x092, yes? That's a modified version of the "CCDX", the CCD_OS/X ROM (located at 0x087). As such, it's a precursor of the definitive "OSX3", i.e AMC_OS/X Bank-switched module... enough to get your head spin ;-) In summary, IMHO the AOSX image is a little old but worthwhile keeping there , if anything the slot could be reused later on by a newer module (space in the lower 1MB is at a premium) RE: AMC-OSX Question - Sylvain Cote - 02-18-2020 02:20 PM (02-18-2020 07:21 AM)Ángel Martin Wrote: I guess you refer to the "AOSX" ROM image located at 0x092, yes?No, I am referring to the AMCOSX4.ROM file not listed in one of the mem_ref*.txt OSX entries in mem_ref_v5.txt file Code: 0x087; CCD-OSX.ROM; CCDX; 5; CCD-OSX; ... This is what I get when loading both files in MLDL200 Manager. (AMC-OSX.ROM & AMCOSX4.ROM) Code: ROM Filename : AMC-OSX.ROM | ROM Filename : AMCOSX4.ROM (02-18-2020 07:21 AM)Ángel Martin Wrote: That's a modified version of the "CCDX", the CCD_OS/X ROM (located at 0x087).I know. (02-18-2020 07:21 AM)Ángel Martin Wrote: As such, it's a precursor of the definitive "OSX3", i.e AMC_OS/X Bank-switched module... enough to get your head spin ;-)About a head spin ... I am currently listing all your ROM files and in the process trying to build the dependency and relationship between them. ![]() (02-18-2020 07:21 AM)Ángel Martin Wrote: In summary, IMHO the AOSX image is a little old but worthwhile keeping there , if anything the slot could be reused later on by a newer module (space in the lower 1MB is at a premium)No, keep it there. I am using your modules in a live demonstration of my HHC2020 presentation on Diego's modules. (teasing: 100+ slides and 2 x 1h sessions) One of the demo is with a Clonix-D module with unmerged blocks (2 blocks of 24K). I cannot use 4LIB, WARP & OSX3 at the same time (32K) because it does not fit in the space I have (24K), so I have used 4LIB, WARP & AOSX. (20K) Code: Bk Pg File Code: 0x120; LIBRARY4.ROM; 4LIB; N/A; Library-4; ... Sylvain RE: AMC-OSX Question - Ángel Martin - 02-18-2020 03:46 PM (02-18-2020 02:20 PM)Sylvain Cote Wrote:(02-18-2020 07:21 AM)Ángel Martin Wrote: I guess you refer to the "AOSX" ROM image located at 0x092, yes?No, I am referring to the AMCOSX4.ROM file not listed in one of the mem_ref*.txt ah, so it's a .ROM file in the monthly archive folder but it's not an entry in the IMDB, I got you now... FWIW the latest AMCOSX4.ROM file I have in my local archive is dated May/15/2013, and the latest AMC-OSX.ROM is dated January/20/2012... so it appears the one to keep is the first one of both, my bad for keeping versions with different names! (02-18-2020 02:20 PM)Sylvain Cote Wrote: I am using your modules in a live demonstration of my HHC2020 presentation on Diego's modules. (teasing: 100+ slides and 2 x 1h sessions) OMG, poor little things.... ;-) Let me know if you have questions but I know you'll do a great show - I'd like a copy when you're done! RE: AMC-OSX Question - Sylvain Cote - 02-18-2020 04:07 PM (02-18-2020 03:46 PM)Ángel Martin Wrote: FWIW the latest AMCOSX4.ROM file I have in my local archive is dated May/15/2013, and the latest AMC-OSX.ROM is dated January/20/2012...ok, so if I understood you correctly, Monte should change this entry Code: 0x092; AMC-OSX.ROM; AOSX; 5; AMC-OSX; ... Code: 0x092; AMCOSX4.ROM; AOSX; 5; AMC-OSX; ... (02-18-2020 03:46 PM)Ángel Martin Wrote: OMG, poor little things.... ;-)LOL (02-18-2020 03:46 PM)Ángel Martin Wrote: Let me know if you have questions but I know you'll do a great show - I'd like a copy when you're done!I will send you a copy when it's ready. RE: AMC-OSX Question - Ángel Martin - 02-20-2020 06:06 AM (02-18-2020 04:07 PM)Sylvain Cote Wrote: ok, so if I understood you correctly, Monte should change this entry Yes, I believe so. A word of caution: the current Library#4 *should* be backwards compatible to support this older AMCOSX ROM , but there is the possibility to have glitches... let me know if you find any. RE: AMC-OSX Question - Sylvain Cote - 02-20-2020 04:48 PM Thank you! I will send en email to Monte about it. Sylvain |
