'√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] (/thread-14532.html) |
'√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Gerson W. Barbosa - 02-18-2020 06:49 PM . ≈e [NT] - Massimo Gnerucci - 02-18-2020 07:38 PM . RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Paul Dale - 02-18-2020 10:00 PM \( \sqrt {\sqrt {\sqrt {\sqrt {2π \sqrt{2} \left( 10^3 \left( 10^3+\frac{π}{3^4} \right)+\frac{1}{π \left(π^5+π^2+1 \right)+\frac{1}{\sqrt{2 π}}}\right) }}}}\) RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Gerson W. Barbosa - 02-18-2020 10:13 PM (02-18-2020 10:00 PM)Paul Dale Wrote: \( \sqrt {\sqrt {\sqrt {\sqrt {2π \sqrt{2} \left( 10^3 \left( 10^3+\frac{π}{3^4} \right)+\frac{1}{π \left(π^5+π^2+1 \right)}+\frac{1}{\sqrt{2 π}}\right) }}}}\) Looks like the algebraic expression has been incorrectly parsed. As it is above, half the correct digits are lost. The HP 50g parses it right, but obviously it will show e to only 12 digits. ------- \[\sqrt[16]{2\pi\sqrt{2} \left \{ 10^{3}\left ( 10^{3}+\frac{\pi }{3^{4}} \right )+\left [ \pi \left ( \pi ^{5}+\pi ^{2} +1\right )+\frac{1}{\sqrt{2\pi }} \right ]^{-1} \right \}}=e-5.29\times 10^{-17}\] RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Paul Dale - 02-19-2020 02:51 AM I mis-parsed the parenthesis placement Fixed now. Pauli RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Gerson W. Barbosa - 02-19-2020 04:36 AM (02-19-2020 02:51 AM)Paul Dale Wrote: I mis-parsed the parenthesis placement Yes, too many parentheses. Quite easy to get lost, that’s why I used the HP 50g (m48+ emulator) Equation Editor. ——- \( \sqrt {\sqrt {\sqrt {\sqrt {2π \sqrt{2} \left( 10^3 \left( 10^3+\frac{π}{3^4} \right)+\frac{1}{π \left(π^5+π^2+1 \right)+\frac{1}{\sqrt{2 π}}}\right) }}}}\) Using only one-digit mantissas, the digits 0 through 5, π, the square root symbol and two pairs of parentheses to yield the first 17 digits of e. If I were mean, I would have posted this as a mini-challenge :-) RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Dave Britten - 02-19-2020 12:52 PM It looks like you guys might need to fix your baud rate. RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Gerson W. Barbosa - 02-19-2020 06:34 PM Here’s a double pandigital expression: '9/5-1/(30*672*√√4+8)+√(9/5-1/(30*672*√√4+8))' →NUM -> 3.14159265362 ( From Ramanujan’s '9/5 + √(9/5) = 3.1416407865' ) These are as easy to find as they are useless and futile. RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - BruceH - 02-19-2020 09:24 PM (02-19-2020 12:52 PM)Dave Britten Wrote: It looks like you guys might need to fix your baud rate. Where's the like button? :-) That took me back. In my head I now have that V.92 connection "be-dang, be-dang" ear-worm going. RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Paul Dale - 02-20-2020 12:36 AM (02-19-2020 06:34 PM)Gerson W. Barbosa Wrote: These are as easy to find as they are useless and futile. They are still fun Pauli RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - mfleming - 02-20-2020 01:36 AM (02-19-2020 09:24 PM)BruceH Wrote: That took me back. In my head I now have that V.92 connection "be-dang, be-dang" ear-worm going. I once had the Telebit "moose call" as a ringtone, but yeah, it was just as annoying as you might think! RE: '√√√√(2*√2*π*(10^3*(10^3+π/3^4)+1/(π*(π^5+π^2+1)+1/(√(2*π)))))' [NT] - Gerson W. Barbosa - 02-20-2020 07:29 PM . How to convert RPL algebraic expressions to LaTeX Copy the algebraic expression to the HP 50g emulator: 'ƒƒƒƒ(2*‡*ƒ2*K(10^3*K(10^3+‡/3^4)+1/(‡*K(‡^5+‡^2+1)+1/ƒ(2*‡))))' ƒ = √; ‡ = \(\pi\); = → (Place K before every opening parenthesis you want to show up in the formula) Then on the emulator do OBJ→ →HP2TX "\cdot" "" SREPL DROP ( "\cdot" "" SREPL DROP only in case you want to remove all dots in the expression ) where →HP2TX is the last object in the hp2txt directory, by forum member peacecalc here. That will return the corresponding LaTeX expression: \sqrt{\sqrt{\sqrt{\sqrt{2\ \pi \ \sqrt{2}\ \left({10}^{3}\ \left({10}^{3}+\frac{\pi }{{3}^{4}}\right)+\frac{1}{\pi \ \left({\pi }^{5}+{\pi }^{2}+1\right)+\frac{1}{\sqrt{2\ \pi }}}\right)}}}} Append /\[ and/\] to the beginning and end... and voilà! \[\sqrt{\sqrt{\sqrt{\sqrt{2\ \pi \ \sqrt{2}\ \left({10}^{3}\ \left({10}^{3}+\frac{\pi }{{3}^{4}}\right)+\frac{1}{\pi \ \left({\pi }^{5}+{\pi }^{2}+1\right)+\frac{1}{\sqrt{2\ \pi }}}\right)}}}}\] "\cdot" "" SREPL should have removed the "\" in "\cdot", but it didn't. Remove them manually if don't want the extra spaces: \[\sqrt{\sqrt{\sqrt{\sqrt{2 \pi \sqrt{2} \left({10}^{3} \left({10}^{3}+\frac{\pi }{{3}^{4}}\right)+\frac{1}{\pi \left({\pi }^{5}+{\pi }^{2}+1\right)+\frac{1}{\sqrt{2\ \pi }}}\right)}}}}\] |
