(SR-52) Cased Oil Wells cement sheath thickness - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: (SR-52) Cased Oil Wells cement sheath thickness (/thread-14547.html) |
(SR-52) Cased Oil Wells cement sheath thickness - SlideRule - 02-22-2020 01:09 AM An extract from The Acoustical Determination of Cement Sheath Thickness In Cased Oil Wells, The University of Oklahoma, Doctorate of Engineering Dissertation, 1978 " The Cement Bond Log has normally been proposed. In the current lliterature as a refraction analysis in which formation signals along with amplitude attenuation of casing signals are a determination of good bond between casing and formation walls. This paper presents a different approach which also takes into account reflection analysis due to the peculiar geological configuration affecting cased well measurements in South Louisiana. Ray theory and wave theory interact to present a solution to the travel time path required to attempt an acoustical determination of the cement thickness. The Wavefront Angle was also taken into account in the analysis since it Is a major factor involved in the delay times related to the travel path, A program was developed and implemented to be easily used in field interpretation at the well-site. The Texas Instruments programmable SR-52 with a PC-100 thermal printer, the open hole sonic log, and the CBL seismogram are all that is required to make the measurement … … A true mud angle program was implemented on the Texas Instruments SR-52 calculator to compute a cement thickness measurement based on a mud/casing interface angle of incidence required to cause either a critical or a reflection angle in the cement … … APPENDIX IV TEXAS INSTRUMENTS SR-52 PROGRAM CODE " Documentation? It's a doctoral thesis! BEST! SlideRule |
