How to simplify result from domain function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: How to simplify result from domain function (/thread-14594.html) |
How to simplify result from domain function - teerasak - 03-02-2020 07:58 AM I use domain() function to find the domain of function Sqrt(x^2-9)/(x-3) The calculator returns result [x<=-3 x>=3 and x <>3] When simplify, it is expected to have [x<=-3 x>3], but the calculator returns result [x<=-3 x>=3] How can we have correct simplified answer? RE: How to simplify result from domain function - Albert Chan - 03-02-2020 12:47 PM The bug probably not from simplify, but x≠3 XCas> purge(x) XCas> x >= 3 // returns x ≥ 3, as expected XCas> x != 3 // returns true ??? XCas> [(x <= -3), (x >= 3) and (x != 3)] // dropped "and true", returns [x <= -3, x >= 3] RE: How to simplify result from domain function - parisse - 03-02-2020 01:18 PM It's unfortunately unavoidable. x!=3 will return true, because in this test x is considered to be a variable, and a variable is not the same as an integer. RE: How to simplify result from domain function - teerasak - 03-03-2020 05:46 AM I see. So the calculator treats x>=3, x<>3 as logical comparison rather than a set of number. Any representation of the set x>=3? RE: How to simplify result from domain function - parisse - 03-03-2020 06:06 AM There is an internal representation, used by assume/about, but no user commands. RE: How to simplify result from domain function - compsystems - 03-03-2020 05:18 PM A new command to graph interval is very important, for example to graph the solution [x≤-3, (x≥3) AND (x≠3)] the following instruction is required F1(X):=PIECEWISE( X≤-3, 0, (X≥3) AND (X≠3), 0 ) [enter] [plot] RE: How to simplify result from domain function - CyberAngel - 03-03-2020 08:55 PM (03-03-2020 06:06 AM)parisse Wrote: There is an internal representation, used by assume/about, but no user commands. Any way of adding an exported command or function? Would it be useful in the described cases? – – VPN RE: How to simplify result from domain function - parisse - 03-04-2020 08:10 PM No, there is no support for the internal representation of assume in user commands. RE: How to simplify result from domain function - CyberAngel - 03-04-2020 09:02 PM (03-04-2020 08:10 PM)parisse Wrote: No, there is no support for the internal representation of assume in user commands. I know there isn't at the moment but would it be useful if you would ADD such a support? Is it possible to add new keywords? like this: "set { x<3 x>3 }" VPN RE: How to simplify result from domain function - parisse - 03-05-2020 06:31 AM There is nothing planned. I have myself no idea how to handle properly these kinds of objects. RE: How to simplify result from domain function - CyberAngel - 03-05-2020 07:54 AM (03-05-2020 06:31 AM)parisse Wrote: There is nothing planned. I have myself no idea how to handle properly these kinds of objects. okay Users just have to careful and also know – not just the math but also the limitations of their tools. – – VPN |
