WP 34s alternate quartz - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP 34s alternate quartz (/thread-14693.html) |
WP 34s alternate quartz - Siegfried - 03-22-2020 04:42 PM I am trying to use the Corona-induced spare time at home to work off my pile of unfinished electronics projects, one of them two WP34s. Conrad is out of the round quartzes mentioned in the manual but has SMD quartzes with the same specs. Can those be used? https://www.conrad.at/de/p/euroquartz-uhrenquarz-eq161-32-768-12-5-smd-2-32-768-khz-12-5-pf-3-2-mm-1-5-mm-0-75-mm-1-st-1009276.html RE: WP 34s alternate quartz - Siegfried - 03-22-2020 04:44 PM Or maybe something like this: https://www.conrad.at/de/p/microcrystal-uhrenquarz-ms3v-t1r-32-768khz-12-5pf-20ppm-ta-qc-smd-2-32-768-khz-12-5-pf-6-7-mm-1-4-mm-1-48-mm-1-st-1009255.html RE: WP 34s alternate quartz - Eric Rechlin - 03-23-2020 01:15 AM I've used this with success: https://www.mouser.com/ProductDetail/695-CMR200T32768DZFT |
