[VA] SRC #007 - 2020 April 1st Ramblings - Printable Version
+--- Thread: [VA] SRC #007 - 2020 April 1st Ramblings (/thread-14752.html)
[VA] SRC #007 - 2020 April 1st Ramblings - Valentin Albillo - 04-01-2020 06:52 PM
Hi all, welcome to my new SRC #007 - 2020 April 1st Ramblings:
As usual, every time April 1st comes by I tend to indulge in assorted math/computing ramblings, 9 of which I'll presently share with you. Also, you surely own a favorite HP calc which you're proud to show off to everyone and their uncle, and you have no trouble solving whatever math problems or computing tasks come your way using it, so this will be an ideal opportunity to put it to work for good. Let's begin:
      Note: In what follows, [x] is the integer part of x, {x} is the fractional part of x, and Ceil(x) is the ceiling of x, e.g.: [3.14] = 3, {3.14} = 0.14, Ceil(3.14) = 4.
1) Solving a system of N plain-vanilla linear equations in N unknowns is dead easy with most HP calculators but as soon as you introduce some very minor changes things aren't that easy anymore. For instance I wonder what the solution is for this system:
       u  + [v] + {w} = 200.0
      {u} +  v  + [w] = 190.1
      [u] + {v} +  w  = 178.8
2) In the same vein, we're used to the fact that a plain-vanilla 2nd-degree equation has exactly two roots, real or complex, and our HP calcs have no problem finding them. But I wonder about the real roots of this slightly-modified "2nd-degree" equation (how many roots, their values ...):
      x2 - 10 [x] + 12.75 = 0
3) Now, here's another 2nd-degree equation in X:
      X2 + 2 X + 5 I = 0
with the caveat that this time X is not just some scalar value but a square matrix and I is the corresponding Identity matrix. Matricial equations can have any number of roots, including an infinity of them or none at all, and it would be nice to find some roots for this equation, if they do exist.
4) Also, after dealing with finding some roots of the above matricial equation I then considered the converse problem, i.e.: to find an Nth-degree equation which has a given NxN square matrix as a root. For instance, I wonder what 3rd-degree matricial equation (if any) would have the following 3x3 matrix as a root:
       2     3     5
       7    11    13
      17    19    23
5) The Nth Fibonacci number (belonging to the well-known Fibonacci sequence: 1, 1, 2, 3, 5, 8, 13 ...) is given by an expression involving one or two exponential functions aN, where a is the Golden Ratio, 1.618+. Since the hyperbolic functions are also combinations of exponential functions ex, where e is 2.718+, I wonder if there's some simple way to express the Nth Fibonacci number using them, perhaps as simple as a few lines of RPN/RPL code or a short single-line user-defined function, used like this:
      FNF(1) = 1, FNF(2) = 1, FNF(3) = 2, ..., FNF(10) = 55, ...
6) The following expression (where N > 0 is an integer and log2 is the natural logarithm of 2 = 0.693+):
      Ceil(2/(21/N - 1)) = [2*N/log2]
seems to be an identity for all integer values of n. For instance for N = 1 both sides equal 2, for N = 5 both sides equal 14, and for N = 2020 both sides equal 5828. Now I wonder if there are any exceptions at all and, if yes, whether a short program (say 4 lines of code) would be able to very quickly find the first three.
7) I'm a fan of Star Trek since always and yesterday I came up with the following hypothetical, idealized scenario (assume all times and distances are exact and lightspeed is exactly 300,000 Km per second):
      Captain Kirk is in command of the USS Enterprise and has to carry out a most critical mission: an unstable star is going supernova exactly 6 weeks from the present moment, destroying several inhabited planets and causing massive loss of life. However, the explosion can be inhibited using certain exotic ore available in some other nearby uninhabited system located just 504 lighthours away, so the USS Enterprise is ordered to travel there, beam the ore onboard, then return to the unstable star and use the ore to stop the supernova explosion from ever happening.
      Now, the USS Enterprise can use two different types on engine. The main one is the warp engine, which is used for interstellar travel and can achieve faster-than-light speeds depending on the cube of the warp factor engaged, i.e., warp 2 achieves 23 = 8x lightspeed, while warp 10 achieves 103 = 1,000x lightspeed. The other engine type is the impulse engine, which is used while orbiting some planet or coasting to a starbase and other such relatively low-speed navigation as well as for emergencies, achieving all speeds from 0 at rest to just shy of lightspeed at full impulse.
      As (pretty bad) luck would have it, the very moment the USS Enterprise starts her journey to reach the ore the warp engine suddenly fails utterly and further Scotty reports that without the help of the warp field the impulse engine can only achieve half impulse (= 150,000 Km per second) so that's what Kirk orders and the Enterprise goes for the ore at half impulse while warp engine repairs are underway on the double.
      Nevertheless, despite the unexpected setback Kirk's not especially worried as he knows his starship is capable of sustaining speeds up to warp 14 (2,744x lightspeed) if needed for the return leg of the journey and fortunately by the time the USS Enterprise arrives at the ore and beams it aboard (which takes no significant time, assume instantly) the warp engine is back to fully operational status and thus Kirk sets for immediate return to the unstable star to try and arrive still within the inescapable deadline.
      That said, the question I pondered is this: What is the minimum warp factor Kirk should engage in order to meet the deadline and avoid massive loss of life ?
8) And speaking of Kirk, Picard's Little Theorem says that there's at most one value which an entire function does not assume. For instance, exp(z) is analytic in the whole complex plane and so is representable by an everywhere convergent power series, thus it's an entire function and the only value it omits is 0 because exp(z) is never 0 for any finite complex argument z, so it complies with Picard's LT alright. So far so good.
Now consider the function exp(exp(z)), which is also an entire function, with a power series convergent everywhere and all that jazz. Being of the form exp(something) it omits 0 because exp(z) does. But then it also omits 1 ( = exp(0) ), because its argument is exp(z), which omits 0. Thus there are two values it doesn't take (0 and 1), contradicting Picard's LT. So I wonder: what gives ?
9) As a bonus, a final spread of misc ramblings o'mine:
      - the equation Gamma(x) = Gamma(y) has trivial solutions x = y but surely nontrivial solutions can be found as well ?
      - the Gamma function grows faster than the exponential function, and I wonder at what positive value of x do their graphics cross for the last time.
      - at such value you'll have Gamma(x) = exp(x) for some x and at some other related value you'll have Gamma(Log(y)) = y for some y.
      - Gamma(Pi) and Gamma(-Pi/2) are surprisingly close when rounded to 2 decimal places ...
      - ... but slightly changing Pi to Pi+(2/52)2 above makes both expressions agree to no less than 8 places when truncated.
      - the equation  sin(x)+(7*x+1)*cos(x+1) = x  has a surprising root in the interval [12, 14].
      - and to top it all, some nice square roots:
            Sqrt(95888) = 309.657875727390470000000975517...
            Sqrt(22008840) = 4691.3580123456789961013...
            Sqrt(40850970) = 6391.4763552719179248943697799317869709544850492715609207148954163663
                                  8031627876551744428575854110967050931635948387731415926546989...
I'll eventually post some additional comments on all 9 ramblings above but let's see your comments first (if any).
Have a nice week and, if you're keeping confinement, I hope this humble effort of mine will offer you some hopefully welcome diversion for a little while. Take care !  Smile
V.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Eddie W. Shore - 04-01-2020 07:36 PM
I'm grateful for the diversions, Valentin. Live long and prosper.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Albert Chan - 04-01-2020 11:49 PM
(04-01-2020 06:52 PM)Valentin Albillo Wrote:  1) Solving a system of N plain-vanilla linear equations in N unknowns is dead easy with most HP calculators but as soon as you introduce some very minor changes things aren't that easy anymore. For instance I wonder what the solution is for this system:
Add them all, and halved it, u+v+w = 568.9/2 = 284.45 → {u}+{v}+{w} = .45, 1.45, 2.45
Assume {w}=0, eqn1 → {u}=0, eqn2 → {v}=.1, sum of fractional part does not match any of above.
Thus, eqn1 → {u}+{w} = 1 → {v} = 1.45-1 = .45
→ {u} = {190.1 - .45} = .65
→ {w} = 1 - {u} = .35
Removing all [], {}:
u + v = 200.0 + {v} - {w} = 200.1
v + w = 190.1 - {u} + {w} = 189.8
u + w = 178.8 + {u} - {v} = 179.0
→ (u, v, w) = (u+v+w) - (v+w, u+w, u+v) = 284.45 - (189.8, 179.0, 200.1) = (94.65, 105.45, 84.35)
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Paul Dale - 04-02-2020 12:41 AM
#7: Distance to planet is 504 light hours. At half impulse this is 1008 hours of travelling time. There are 168 hours in a week. 1008/168 = 6 weeks exactly. Infinite warp speed would be required to get back and save the doomed system.
Kirk might as well hang around and seduce the inevitably beautiful local alien women ore miners. Except that the system containing the ore is uninhabited. He'll instead seduce the also inevitable beautiful but doomed women for just under six weeks...
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Albert Chan - 04-02-2020 02:10 AM
#2: x² - 10 [x] + 12.75 = 0
({x} + [x])² - 10 [x] + 12.75 = {x}² + 2 [x] {x} + ([x]² - 10 [x] + 12.75) = 0
{x} = -[x] ± √([x]² - ([x]² - 10 [x] + 12.75)) = -[x] ± √(10 [x] - 12.75)
From the radical, to have real {x}, [x] ≥ 2
[x]      {x} = √(10 [x] - 12.75) - [x]
 2       √7.25   - 2 ≈ 0.6926 OK
 3       √17.25 - 3 ≈ 1.1533 BAD
 4       √27.25 - 4 ≈ 1.2202 BAD
 5       √37.25 - 5 ≈ 1.1033 BAD
 6       √47.25 - 6 ≈ 0.8739 OK
 7       √57.25 - 7 ≈ 0.5664 OK
 8       √67.25 - 8 ≈ 0.2006 OK
 9       √77.25 - 9 ≈ -.2108 BAD
All bigger [x] will produce negative {x}, thus no more roots
→ 4 roots = √7.25, √47.25, √57.25, √67.25
RE: [VA] SRC #007 - 2020 April 1st Ramblings - J-F Garnier - 04-02-2020 07:38 AM
(04-01-2020 06:52 PM)Valentin Albillo Wrote:  8)
Now consider the function exp(exp(z)), which is also an entire function, with a power series convergent everywhere and all that jazz. Being of the form exp(something) it omits 0 because exp(z) does. But then it also omits 1 ( = exp(0) )... contradicting Picard's LT. So I wonder: what gives ?
Of course, it doesn't omit 1 :
let's z=log(i*2*Pi*n) , n<>0
exp(exp(z)) = exp(i*2*Pi*n) = 1
Picard's Little Theorem is safe :-)
J-F
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Bernd Grubert - 04-02-2020 03:20 PM
Hi Valentin,
thanks for the interesting excursion.
This is actually a linear equation system consisting of 6 equations:
[u] + [v] = 199
[v] + [w] = 189
[u] + [w] = 178
{u} + {w} = 1.0
{u} + {v} = 1.1
{v} + {w} = 0.8
with u = [u] + {u}, ... and so on.
The constant term on the right side has to been adjusted to give positive solutions for the {}s.
The left side of the equation system can be written as matrix for solving in a calculator:
[1 1 0 0 0 0]
[0 1 1 0 0 0]
[1 0 1 0 0 0]
[0 0 0 1 0 1]
[0 0 0 1 1 0]
[0 0 0 0 1 1]
The solution is [94, 105, 84, 0.65, 0.45, 0.35], which results in:
u = 94.65
v = 105.45
w = 84.35
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Bernd Grubert - 04-02-2020 08:26 PM
(04-01-2020 06:52 PM)Valentin Albillo Wrote:  3) Now, here's another 2nd-degree equation in X:
      X2 + 2 X + 5 I = 0
The solutions of the quadratic equation are -1+2*i and -1-2*i. Trivial square matrices that satisfy the equation are diagonal matrices D that contain the solutions as elements in the diagonal, e.g.:
[-1 + 2 i, 0 ]
[ 0, -1 - 2 i]
Multiplying those diagonal matrices D from the left with an invertible matrix M of the same dimensions and with its inverse from the right
X = M D M-1
is also a solution of the quadratic equation.
This can be seen by multiplying the quadratic equation with M-1 from the left and with M from the right:
M-1 X X M + 2 M-1 X M + 5 M-1 I M =
M-1 (M D M-1) (M D M-1) M + 2 M-1 (M D M-1) M + 5 M-1 I M =
(M-1 M) D (M-1 M) D (M-1 M) + 2 (M-1 M) D (M-1 M) + 5 M-1 I M =
D2 + 2 D + 5 I
by making use of the fact that M-1 M = M-1 I M = I.
By definition the result of this expression is 0 since D is a root of the quadratic equation.
Since D is a solution of the equation so is X = M D M-1.
Therefore there exist an infinite number of solutions for this equation.
Edit: Added parentheses. Restated the conclusion to make it more clear.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Bernd Grubert - 04-02-2020 09:03 PM
(04-02-2020 12:41 AM)Paul Dale Wrote:  #7: Distance to planet is 504 light hours. At half impulse this is 1008 hours of travelling time. There are 168 hours in a week. 1008/168 = 6 weeks exactly. Infinite warp speed would be required to get back and save the doomed system.
I agree with Paul. It is not possible to make it back in time.
However Captain Kirk might think (wrongly) that he has enough time due to time dilatation when travelling at half the speed of light (c) to the planet to pick up the ore. Since he is accelerated and decelerated his clock is slower than those in the rest of the universe by a factor of
1/sqrt(1 - v2 / c2) = 1/sqrt(1 - 1/4) = 2 / sqrt(3).
For him the travel didn't last 1008 h but only 1008 h * sqrt(3) / 2 ~ 873 h. He might think that he still has ~135 h left to travel back to the solar system and prevent the sun from turning into a supernova. The required travelling speed would be ~ c * 504 / 135 ~ 3.73 c in this case. The warp speed would be ~1.55. (I don't know what happens with time during warp speed - does it reverse?).
On the other hand I don't think Captain Kirk would happen such a blunder :-) and I might also be on a totally wrong track.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Albert Chan - 04-02-2020 10:55 PM
(04-01-2020 06:52 PM)Valentin Albillo Wrote:  6) The following expression (where N > 0 is an integer and log2 is the natural logarithm of 2 = 0.693+):
seems to be an identity for all integer values of n ...
Let gap = f(N) = 2*N/log2 - 2/(21/N - 1)
Let w = log(2)/N > 0     → f(N) = g(w) = 2/w - 2/(e^w-1)
Since e^w-1 = w + w²/2! + w³/3! + ... > w, we have f(N) = g(w) > 0
f(1) ≈ 0.8854
f(2) ≈ 0.9424
f(3) ≈ 0.9615
f(2020) ≈ 0.9999
Apply L'Hospital's rule for limit(g(w), w=0):
2*(e^w-1 - w) / (w * (e^w-1))
⇒ 2*(e^w-1) / (w*e^w + (e^w-1))
⇒ 2*e^w / (w*e^w + e^w + e^w)
= 2 / (w + 2)
→ f(∞) = g(0) = 2 / (0+2) = 1
Ceil(2/(21/N - 1)) ≥ [2*N/log2]     // LHS > RHS if {2*N/log2} > f(N)
Example: 37th convergents of log2/2 = 777451915729368 / 2243252046704767
With N = 777451915729368     // note: this may not be the first exception case
LHS = Ceil ( 2243252046704766.000000000000000106 ... ) = 2243252046704767
RHS = Floor(2243252046704766.999999999999999957 ... ) = 2243252046704766
RE: [VA] SRC #007 - 2020 April 1st Ramblings - EdS2 - 04-03-2020 08:31 AM
Thanks Valentin for a stimulating post. I can't imagine you can find these patterns in decimal expansions of square roots without a brute force search - if that's so, just how many square roots did you search for patterns?
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Bernd Grubert - 04-03-2020 12:45 PM
(04-01-2020 06:52 PM)Valentin Albillo Wrote:  4) Also, after dealing with finding some roots of the above matricial equation I then considered the converse problem, i.e.: to find an Nth-degree equation which has a given NxN square matrix as a root. For instance, I wonder what 3rd-degree matricial equation (if any) would have the following 3x3 matrix as a root:
       2     3     5
       7    11    13
      17    19    23
The matrix X is a root of its own characteristic polynomial:
X3 - 36 X2 - 32 X +78 I = 0 where I is the identity matrix.
The reasoning is similar to that is in post #8:
The roots of the characteristic polynomial define the eigenvalues of the matrix X. Therefore a diagonal matrix D which contains the eigenvalues in its diagonal are also roots of the characteristic polynomial. The original matrix X is obtained by multiplication of D with a matrix M made from the eigenvectors from the left and with its inverse M-1 from the right:
X = M D M-1
Inserting this into the polynomial and using the fact that
M-1 M = M-1 I M = I
as in post #8 shows that X is also a root of the characteristic polynomial.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Valentin Albillo - 04-09-2020 11:46 PM
Hi all:
Thanks for your appreciation and your excellent inputs to my 9 ramblings. As stated, I'll give here my original comments on them:
1) Re solving the system:
        u   + [ v ] + { w } = 200.0
      { u } +   v   + [ w ] = 190.1
      [ u ] + { v } +   w   = 178.8
Both solutions posted are fully correct, namely u = 94.65, v = 105.45, z = 84.35.
2) Re solving the equation:
Again, the posted solution is correct and the equation has indeed four real roots, namely √29/2, √189/2, √229/2 and √269/2.
It's somewhat funny that simply adding a [] doubles the number of real roots.
3) Solving the matricial equation:
      X2 + 2 X + 5 I = 0
The equivalent scalar equation, x2 + 2 x + 5 = 0, has the two conjugate complex roots (-1, 2) and (-1, -2). Now, a complex scalar (x,y) can be represented as a 2x2 matrix,
      | x   -y  |
      | y    x  |
so, for instance, the complex scalar root (-1, 2) can be represented as
      | -1  -2  |
      |  2  -1  |
and this 2x2 matrix is indeed a root of the matricial equation. The same goes for the matrix corresponding to the conjugate scalar root (-1, -2) and if desired, this simple HP-71B code can be used to check them:
      1  DESTROY ALL @ OPTION BASE 1 @ DIM A(2,2),B(2,2),C(2,2)
      2  MAT INPUT A
      3  MAT B=A*A @ MAT B=B+A @ MAT B=B+A @ MAT C=IDN @ MAT C=(5)*C @ MAT B=B+C
      4  MAT DISP B;
      >RUN
            A(1,1)=?
            -1, -2, 2, -1 [END LINE]
            0 0
            0 0
4) Re finding the matricial equation which has this 3x3 matrix as a root::
       2     3     5
       7    11    13
      17    19    23
As Bernd Grubert posted, by the Cayley–Hamilton theorem, a matrix is always a root of its own characteristic polynomial (which can be found using the 5-liner program featured in page 6 of my article "HP Article VA012 - HP-71B Math ROM Bakers Dozen (Vol. 2).pdf"), which for this matrix happens to be:
      P(x) = x3 - 36*x2 - 32*x + 78
and indeed the given matrix is a root of this polynomial equation in its matricial form: P(X) = X3 - 36*X2 - 32*X + 78 I = 0.
As an aside, the eigenvalues are the roots of the characteristic polynomial, namely 1.10530, -1.91703 and 36.81173. As a check,
      - their sum is 36, which equals the trace (sum of the main diagonal elements) of the matrix: 2 + 11 + 23 = 36
      - their product is -78, which equals the determinant of the matrix, which indeed is -78.
5) Finding some simple way to express the Nth Fibonacci number using them, perhaps as simple as a few lines of RPN/RPL code or a short single-line user-defined function, used like this: FNF(1) = 1, FNF(2) = 1, FNF(3) = 2, ..., FNF(10) = 55, ...
Regrettably no one posted anything about this one so, as usual, I won't comment anything either.
6) Finding exceptions to the following near-identity (where N > 0 is an integer and log2 is the natural logarithm of 2 = 0.693+):
As it happens, the following one is a true identity:
      [(1/(exp(sqr(2)/n)-1)] = [n/sqr(2)-1/2]
but the one given above is only a near-identity with infinite exceptions, the first being n = 777451915729368, as we'll see below.
The near-identity may fail only for those n which are denominators of the num/dem convergents to 2/log(2) so it suffices to generate said convergents and check their denominators. The following generic UBASIC code lists the convergent's numerators num, denominators den and resulting values num/den for any given positive real number x, with max. err = 10-40 and num, den being limited to a maximum of 20 digits (all these limits can be trivially modified in the code below):
      10 point 8 : input X : W=10^(-40) : Md=10^20 : gosub 40
      20 print : print N,D : print N/D : print Z : end
      30 '
      40 V=1 : N=1 : D=0 : Y=10^99 : Z=X
      50 C=int(X) : Fp=X-C : if Fp=0 then N=N*C+U : D=D*C+V : return
      60 X=1/Fp : S=N : T=D : N=N*C+U : U=S : D=D*C+V : V=T : R=N/D : print N; D, R
      70 if abs(R/Z-1)<=W then return
      80 if R=Y or max(N,D)>Md then N=U : D=V : return else Y=R : goto 50
      run
      ? 2/log(2)
       2 1    2.0
       3 1    3.0
       23 8    2.875
       26 9    2.88888888888888888888888888888888888888
       75 26    2.88461538461538461538461538461538461538
       101 35    2.88571428571428571428571428571428571428
       176 61    2.88524590163934426229508196721311475409
       277 96    2.88541666666666666666666666666666666666
       1007 349    2.8853868194842406876790830945558739255
       2291 794    2.88539042821158690176322418136020151133
       10171 3525    2.88539007092198581560283687943262411347
       73488 25469    2.88539008206054419097726648081982017354
       377611 130870    2.88539008176052571253916099946511805608
       1206321 418079    2.88539008177880257080599599597205312871
       7615537 2639344    2.88539008177789632575367212458853412059
       31668469 10975455    2.88539008177793084660271487605753018895
       39284006 13614799    2.88539008177792415444399876928039848403
       70952475 24590254    2.88539008177792714137885684304033622426
       323093906 111975815    2.88539008177792677820652611459001213788
       394046381 136566069    2.88539008177792684359978172909114049405
       717140287 248541884    2.88539008177792681413809513087942956125
The following 4-line particularized code finds and outputs the first three exceptions almost instantly:
      list
      1 point 11 : X=2/log(2) : Z=X : V=1 : N=1 : D=0 : repeat : C=int(X) : F=X-C
      2 if F=0 then end else X=1/F : S=N : T=D : N=N*C+U : U=S : D=D*C+V : V=T
      3 if ceil(2/(2^(1/D)-1))<>floor(Z*D) then print D
      4 until D>10^19
      run
            777451915729368
            140894092055857794
            1526223088619171207
            OK
Let's check them:
      point 10
      n=777451915729368:?ceil(2/(2^(1/n)-1)),floor(2*n/log(2))
            2243252046704767       2243252046704766
      n=140894092055857794:?ceil(2/(2^(1/n)-1)),floor(2*n/log(2))
            406534415799078269       406534415799078268
      n=1526223088619171207:?ceil(2/(2^(1/n)-1)),floor(2*n/log(2))
            4403748962482230453       4403748962482230452
and indeed all three are exceptions, as the left and right sides of the near-identity differ by 1.
7) Finding the minimum warp factor Kirk should engage in order to meet the deadline and avoid massive loss of life:
As has been pointed out by Paul Dale, the ore planet is 504 lighthours away, i.e. 504/24/7 = 3 lightweeks away, and as the USS Enterprise is travelling at half impulse (1/2 lightspeed) it will take her 3/(1/2) = 6 weeks to arrive there so, as the deadline is precisely 6 weeks, it will have zero time to make the return trip to the dangerous star and thus Kirk would need to order an infinite warp factor to (just!) meet the deadline, which his starship of course can't achieve.
The conundrum seems hopeless but Cpt. Kirk's has always distinguished himself (among many other things) for not believing in the unwinnable scenario, as he always does whatever is needed to get the problem solved. He demonstrated as much early in his career, when solving the training "Kobayashi Maru" unwinnable scenario by blatant cheating, reprogramming the simulation so that he could win it alright.
Same here. By the time Kirk arrives at the ore there's no time to meet the deadline but there's a canon maneuver Kirk has used several times in both the TV series and the movie "Star Trek IV: The Voyage Home", consisting in time-traveling to the past by performing the so-called "slingshot around the sun" maneuver, defined by Dr. Leonard "Bones" McCoy as "You pick up enough speed, you're in time warp. If you don't – you're fried."
In essence, the maneuver consists in going very close around a star at high warp speed and its main result (if you don't get fried) is that the starship time-travels (even several centuries in the past/future if needed), so Kirk, which has consistently performed this maneuver a number of times using both the USS Enterprise and a Klingon Bird of Prey, would simply arrive at the ore planet in 6 weeks, beam the ore aboard, and then order high warp towards and around the ore planet's sun (it has one as it's not a rogue planet, it belongs to a system).
The carefully calculated (by Spock) maneuver would succeed in getting the Enterprise a sufficient amount of time in the past, then order whatever achievable warp speed is needed to make it to the potentially-exploding star in time. Thus, once in the past, assuming Kirk orders maximum warp (14) the USS Enterprise will be back in just 504/143 ~ 11 minutes.
It's cheating, I know, but it's perfectly canon and entirely consistent with Kirk's attitude towards "unwinnable" scenarios: he doesn't believe in them.
8) On whether the function exp(exp(z)) appears to contradict Picard's Little Theorem by missing two values in the complex plane, namely 0 and 1:
As J-F Garnier's post makes it perfectly clear, Picard's LT is safe because while exp(something) can never take the value 0 it sure can take the value 1 for (complex) nonzero arguments.
9) As for the final spread of misc ramblings:
            Yes, infinitely many. For instance, both Gamma(-1.33980199358) and Gamma(-1.78118797146) evaluate to 3.00000000000, give or take a few ulps.
      - the Gamma function grows faster than the exponential function, and we find the positive value of x for which their graphics cross for the last time, like this (HP-71B code):
      >FNROOT(1,10,GAMMA(FVAR)-EXP(FVAR))
            7.46360328378
      >X=RES @ GAMMA(X),EXP(X)
            1743.41878559       1743.41878559
      >GAMMA(LN(RES))
            1743.41878559      ( = RES)
      >FIX 2 @ GAMMA(PI);GAMMA(-PI/2) @ STD
            2.29       2.30
      >X=PI+(2/5^2)^2 @ GAMMA(X);GAMMA(-X/2)
            2.30241003575       2.30241009575
      - the equation  sin(x)+(7*x+1)*cos(x+1) = x  has a surprising root in the interval [12, 14], namely:
      >FNROOT(12,14,SIN(FVAR)+(7*FVAR+1)*COS(FVAR+1)-FVAR)
             12.9999999016
      which is a near-integer very close to 13. Indeed, 13 almost satisfies the equation:
      >SIN(13)+(7*13+1)*COS(13+1)
            12.9999911119      (i.e.: ~13)
As for the nice square roots and to answer EdS2 question, yes, I did use brute-force to find such patterns (and many more !) but I didn't keep a count of how many square roots did I have to search, surely quite a lot. However, the search is quite fast so finding patterns up to, say, 10 digits while looking at (say) 100-decimal square roots didn't take long and I could indulge in it without wasting undue amounts of time,
That's all, Have a nice weekend and take care !  Smile
V.
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Paul Dale - 04-10-2020 08:51 AM
For question 5, I came across this paper by Trzaska which explains all.
The transformation from Φ to Ψ eluded me, unsurprisingly.
Pauli
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Juan14 - 04-12-2020 03:13 PM
I am late but I wanted to post this for question number 5.
If Fn is the n Fibonacci number and φ = (1+√(5))/2 (golden ratio) we have:
Fn = 1/√(5) [φ^n - (-φ)^(-1)] = 1/√(5) [φ^n - (-1)^(-n)*φ^(-n)]
= 1/√(5) [exp(n*ln(φ)) - (-1)^(n)*exp(-n*ln(φ))]
= 2/√(5) [exp(n*ln(φ)) - (-1)^(n)*exp(-n*ln(φ))]/2
When n is even:
Fn = 2/√(5) [exp(n*ln(φ)) - exp(-n*ln(φ))]/2
= 2/√(5) sinh(n*ln(φ))
When n is odd:
Fn = 2/√(5) [exp(n*ln(φ)) + exp(-n*ln(φ))]/2
= 2/√(5) cosh(n*ln(φ))
A program for the 50g.
5. √ 2 / DUP2 .5 + * LN ROT 2 MOD { COSH } { SINH } IFTE SWAP / 0 RND
RE: [VA] SRC #007 - 2020 April 1st Ramblings - Valentin Albillo - 04-16-2020 04:41 PM
Hi, all:
I see that Paul Dale and Juan14 recently addressed my Rambling 5, which was left unanswered so far, so thanks to both of you for addressing it and consequently I'm giving here my original solution and comments (all code is for the HP-71B + Math ROM):
Quote:5) Finding some simple way to express the Nth Fibonacci number using them, perhaps as simple as a few lines of RPN/RPL code or a short single-line user-defined function, used like this: FNF(1) = 1, FNF(2) = 1, FNF(3) = 2, ..., FNF(10) = 55, ...
My original solution consists of the following code, which simply initializes two numeric variables (one real, one complex) to hold some constants for efficiency's sake, and then implements a single-line user-defined function FNF(N), which takes N (whether integer or not) and uses a single instance of the Hyperbolic Sine (SINH) function (as required) of a complex argument to directly return the N-th Fibonacci number, FN :
      1  DESTROY ALL @ COMPLEX Z @ X=2/SQR(5) @ Z=(LN((1+SQR(5))/2),PI/2)
      2  DEF FNF(N)=REPT(X*SINH(N*Z)/(0,1)^N)
Unlike Juan14's solution, mine doesn't distinguish between odd N and even N, a single SINH suffices for every real N. Also notice that (0,1) is the value i (the imaginary unit) and (1+√5)/2 is φ, the Golden Ratio. Let's check it:
      >RUN      (just once, to initialize the two needed constants)
and now we'll use FNF directly from the command line to compute and display the first 16 Fibonacci numbers F1 .. F16
      >FOR N=1 TO 16 @ DISP USING "2D,2X,3D.8D";N;FNF(N) @ NEXT N
            1      1.00000000
            2      1.00000000
            3      2.00000000
            4      3.00000000
            5      5.00000000
            6      8.00000000
            7     13.00000000
           15    610.00000000
           16    987.00000000
which are fully correct. The argument N isn't constrained to be an integer so we can compute F20.20 like this:
      >FNF(20.20)
            7448.4401
and we can check the basic recurrence FN + FN+1 = FN+2 for N = 20.20 like this:
      >FNF(20.20)+FNF(21.20),FNF(22.20)
            19500.2694   19500.2694
Just for fun, let's compute FPi and Fe :
      >STD @ FNF(PI),FNF(EXP(1))
            (FPi =) 2.11702705791   (Fe =) 1.7308152698
(notice that when rounded to 4 digits we coincidentally have Fe = 1.731 while √3 = 1.732 and thus we have Fe ~ √3 )
Last, and also for fun, let's compute N such that FN is a given value, i.e: inverse Fibonacci. Add this 3rd program line:
      3  INPUT F @ FNROOT(1,100,FNF(FVAR)-F) @ GOTO 3
and let's try some values:
      >FIX 8
      >RUN
           ? 55
                     10.00000000    (F10 = 55)
           ? 6765
                     20.00000000    (F20 = 6765)
           ? PI
                     4.09041655     (F4.09041655 = Pi)
           ? 2020
                     17.48828958    (F17.48828958 = 2020)
Regards.
V.
