HP Prime will not turn off for more than 2 seconds. - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: HP Prime will not turn off for more than 2 seconds. (/thread-14817.html) |
HP Prime will not turn off for more than 2 seconds. - AcoustricBruce - 04-08-2020 06:01 PM I bought the HP Prime about 1 week ago. I have used it daily. I have worked with it and shut it down many times. Today I did a factory reset using CFO and reset on back, format and reset option. Everything seemed to work great. Calculator is working fine. Until I noticed: I shut it down and it came back on within 2 seconds. I let it sit until it dimmed, then it shut down on its own, then came back on within 2 seconds. This is definitely odd behavior. Has anyone here had this issue? What should I do? RE: HP Prime will not turn off for more than 2 seconds. - Carlos295pz - 04-09-2020 06:16 AM RE: HP Prime will not turn off for more than 2 seconds. - DrD - 04-09-2020 09:47 AM Have you tried the pin hole reset? Maybe there is some kind of foreign matter stuck in the on key. In which case it may be a warranty issue, and you might contact hp support for guidance. -Dale- RE: HP Prime will not turn off for more than 2 seconds. - Joe Horn - 04-09-2020 12:50 PM (04-08-2020 06:01 PM)AcoustricBruce Wrote: I bought the HP Prime about 1 week ago. I have used it daily. I have worked with it and shut it down many times. Today I did a factory reset using CFO and reset on back, format and reset option. Everything seemed to work great. Calculator is working fine. Until I noticed: If your Prime is a G2, then it's a known bug in some firmware versions. This "Won't Stay Off" mode can be intentionally started by unplugging the USB cable (if any) and then exiting the C+F+O diagnostic screen by pressing 9. There are several ways to revive your G2's ability to turn off normally: Method #1: Enter Coma Mode (hold down Shift, then press and hold On for one second, then release both), then power back up. Method #2: Exit C+F+O diagnostic screen by pressing the C key (not the 9 key as usual). Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice. RE: HP Prime will not turn off for more than 2 seconds. - rprosperi - 04-09-2020 11:42 PM (04-09-2020 12:50 PM)Joe Horn Wrote: Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice. Method #3 is hilarious! I had to check the calendar to be sure it wasn't April 1st... Is it really twice or will any even number do? RE: HP Prime will not turn off for more than 2 seconds. - Joe Horn - 04-10-2020 12:11 AM (04-09-2020 11:42 PM)rprosperi Wrote:(04-09-2020 12:50 PM)Joe Horn Wrote: Method #3: With Prime plugged into a powered USB cable, turn Prime off and back on, twice. Strange but true. Twice returns Prime to normal, so any subsequent power cycling has no effect on that bug. |
