Saving CAS history - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Saving CAS history (/thread-14825.html) |
Saving CAS history - Pjwum - 04-09-2020 03:46 PM Hi, every time a new firmware is published I hope for a new way to save my CAS screen history, but so far without success. When I have worked on a problem in CAS it would be nice if there was a save feature. I could resume the other day and meanwhile use the CAS for different things. Still I can't find something like "Save as .." in the CAS menu or the Mem-screen. A "copy all" also seems not possible. Do you guys know a way or found a workaround to backup your CAS calculations history? Patrick RE: Saving CAS history - Dands - 04-09-2020 04:43 PM Create a calculator backup in the connectivity kit app before upgrading, then restore it. Unfortunately the Prime doesn't have a tabbed calculator mode as the TIs do, allowing you to save your work separately. |
