Card reader programs HP-97 to HP-41C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Card reader programs HP-97 to HP-41C (/thread-14847.html) |
Card reader programs HP-97 to HP-41C - Moggul - 04-14-2020 11:16 AM I have several prgrams in my HP-97 that I am trying to load into my HP-41C. The programs load ok in the 41C but then I am unable to run them. The converted programs always start with "LABEL 97" and then they do not appear on Catalog 1. I have tried renaming the program and adding an END at the end but still can't make them work. What am I doing wrong? Thanks!!! RE: Card reader programs HP-97 to HP-41C - BobVA - 04-14-2020 01:37 PM A couple of easy things to check: - Make sure you've got at least 26 registers allocated (i.e. SIZE? should return a value of at least 26) - Leave the card reader attached while running the program. (It contains ROM routines needed to execute some functions.) RE: Card reader programs HP-97 to HP-41C - Moggul - 04-14-2020 03:40 PM (04-14-2020 01:37 PM)BobVA Wrote: - Make sure you've got at least 26 registers allocated (i.e. SIZE? should return a value of at least 26) Thank you Bob, increasing the number of registers did the trick!!! RE: Card reader programs HP-97 to HP-41C - BobVA - 04-15-2020 12:04 AM Cool! Glad that worked! |
