HP 32S - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 32S (/thread-14883.html) |
HP 32S - Jorge Tucakov - 04-22-2020 08:50 PM Hello, I have an HP 32S calculator and I need to change the display, I would like to know if the HP 20S display is compatible. Thanks for some info Jorge Tucakov RE: HP 32S - Csaba Tizedes - 04-22-2020 09:18 PM (04-22-2020 08:50 PM)Jorge Tucakov Wrote: Hello, I have an HP 32S calculator and I need to change the display, I would like to know if the HP 20S display is compatible.Hello, the 32S has dot matrix LCD (5×7 pixels) and the 20S has 7-segment LCD, so I think these are not compatible. Csaba RE: HP 32S - Wizard1983 - 04-23-2020 03:09 AM I agree if you look at the Pioneer internal you will find there are several different screens in the various models from the 10B to the 42S Here is a snip from the excellent description by Paul Brogger https://www.hpmuseum.org/guest/brogpion.htm Different LCD's There are at least four different LCD units employed in the various Pioneer models, and (as noted above) perhaps a couple variations of some of those. The high-end models (17B, 27S and 42S) apparently use the same 16x131 dot-matrix display. I'm guessing that the HP-17BII does as well, but I haven't had any of the 17B's apart, and don't know for sure. (If this is so, it should be possible to replace a broken HP-42S display by buying a current-model HP-17BII.) This display enables the two-line display, labeled menus and limited graphing capabilities. The mid-range models (14B, 22S, 32S, etc.) seem to use the same single-line, large-numeral, alphanumeric LCD. This display utilizes 5x7 LCD dot matrices for more readable characters and numerals, but it is not a general-purpose graphic display. The HP-32SII display is a variation on the 32S, with even larger, more readable characters and two shift annunciators. The low-end Pioneer display is a 7-segment display used in the 20S and 10B calculators. |
